20 Most Recent EliteGroup ECS 661FX-M Main Board Socket 478 for Intel Pentium 4 processor (MBEC661FXM) Motherboard Questions & Answers
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
EliteGroup ECS... | Answered on Mar 30, 2011
  • Go to your MB specification Page
  • Click the Download button
  • select sound>Download link(USA/china)
  • Download it and install
if you can't do this then simply go to this link
EliteGroup ECS... | Answered on Jan 13, 2011
Hi, you will need to install the driver for your display before you can increase your resolution. Try this link for your drivers:
http://driverscollection.com/?V=ECS%20(Elitegroup)&S=4
EliteGroup ECS... | Answered on Sep 18, 2010
Anything MORE than ONE beep indicates that the motherboard has detected a problem:
* bad RAM
* RAM not correctly "seated" in its socket
* one of the fans powered by the motherboard (CPU, case) is not spinning, or is not spinning fast-enough
* bad video-card
EXACTLY what sequence of "sounds/beeps" you do hear?
EliteGroup ECS... | Answered on Jul 30, 2010
try
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=392&DetailName=Feature&MenuID=1&LanID=0
EliteGroup ECS... | Answered on Apr 22, 2010
The audio driver is a Realtek HD Audio and the lan driver should be a Realtek driver also - they can both be downloaded from links on this page.
Post your results here, especially if that link doesn't fix your problem.
EliteGroup ECS... | Answered on Apr 09, 2010
I'm thinking you need a new CMOS battery.
The battery number should be a 2032. It's on your motherboard and is a little smaller than a US quarter
EliteGroup ECS... | Answered on Dec 28, 2009
Here's a link to where you can download all drivers for this motherboard:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=392&DetailName=Driver&DetailDesc=661FX-M%28V1.0B%29&CategoryID=1&MenuID=74&LanID=0
EliteGroup ECS... | Answered on Nov 16, 2009
You can find & download all drivers for this motherboard at the following link:
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=392&CategoryID=1&DetailName=Driver&MenuID=1&LanID=0
EliteGroup ECS... | Answered on Jul 09, 2009
type the motherboard manufacture name in google search infront of the download word
please insert the sound card on PCI slot correctly
CLICK HERE
This will give you the driver page for ECS P4M800-M(V1.0A)
Also in the *NEW* tab there is updated BIOS and VGA.
EliteGroup ECS... | Answered on Mar 26, 2009
Hi there.
If you get a bios/post screen the the system is recognizing the memory, take the system memory out and clean the contacts and the slots with a dry, clean paintbrush. Re-seat the memory and re-start the machine, if it still loops you may have to clear the cmos, look at the motherboard near the battery for a plastic jumper like this >>cb272d4.jpg move to the other position and hit the on/off button (nothing will happen) then put it back in its original position and power the machine up, this should work and you will have to set the date and time again.
If you can't find a jumper take the motherboard battery out for an hour making sure you pull the power cord from the back first.
Good luck and thanks for using FixYa!!
EliteGroup ECS... | Answered on Mar 14, 2009
I have a cd driver for elite motherboard but i have to look at the E2160 code if they are the same. I`ll tell you if compatible.
EliteGroup ECS... | Answered on Jan 04, 2009
Well that makes 2 of us sparky, I never heard of that either nor do I know what skpe is. Lets just put this error code aside for now. Right click on My Computer & slide down to properties. Click on the Hardware tab than open Device Manager. Scroll down to Sound, video & game controller. Click the + sign. Do you see a yellow ! point at any device there? Now open control panel and open Sound & Audio device. Click the Audio tab. Is Realtek AC97 Audio listed there? Than click Voice tab, the same should be listed there. If Realtec AC97 was not listed reinstall your audio drivers. Click the link below & download from ECS. In referance to the mouse. If you installed new mouse drivers when you connected that new mouse, uninstall that software.
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=401&DetailName=New&DetailDesc=661FX-M%20Deluxe%20%20(V1.0)&CategoryID=1&MenuID=82&LanID=0
I did not find any referance to code 1 through microsoft or at ECS. Please post back so I can make some sense of this.
Good luck sparky!
please vote...
EliteGroup ECS... | Answered on Feb 02, 2008
If it is quite old it may not have an AGP slot in that case you will need to buy a PCI card for it.
EliteGroup ECS... | Answered on Dec 12, 2007
The ECS website.
EliteGroup... | Answered on Oct 19, 2018
EliteGroup ECS 661FX-M Main Board Socket 478 for Intel Pentium 4 processor (MBEC661FXM) Motherboard Logo
24 questions posted
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Matson Kurian
Matson Kurian
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
just re installed windows
  • Computers & Internet
