20 Most Recent
Arcsoft Magic-i Visual Effects Questions & Answers
Installing hp webcam 2100 and
Try running the program in compatibility mode for an older version of windows such as vista or xp. If it still causes the usb problems it may have to do with outdated usb drivers. Try running the program in safe mode and see if that works.
If it will only work in safe mode and your usb drivers cant be changed, then you should just buy a new webcam for install a generic webcam driver for it.
How do I operate my webcam? because it does not
How to capture images from your webcam easily.
Sometimes you do know that the webcam has been installed successfully and is working , while you chat, but you are not aware as to how do you use that webcam to take an image of yourself, or any image that you want to take using your webcam.
The procedure is simple.
- All you need to do is find a good third party software which could be used as an application to capture images from your webcam.
- This application would not just capture the image , but also save it on your hard disk as per the required format , most probably , jpeg or bmp as per your choice.
- I would suggest you to download one such application and give it a try by clicking this link --> http://bit.ly/kT5PkH
Hope this helps ..:)
Stupid magic-i program is not
Hi my friend. If a program you wanted to delete still refuse to be terminated, or erased, then approach that program outside of it's territory. First, restart your computer, while your computer start to boot, pressing F8 continuesly , you'll be directed to several options that include to start your computer with command prompt. Select this option by left clicking on it with your mouse. This will appear -- c>
Example:
C:\cd program (press enter)
C:\program> (type dir/w then press enter) this is to find the stupid ( Magic I Program that we wanted to delete ) if you found it, from the C:\ command prompt, type del filename of the said program that needs to be deleted.
Example:
C:\del magic-I visual ( press enter ).
The program that you wanted to be deleted, is successfully terminated.
Hope this would help you . Have a nice day my friend.
Magic-i came preloaded on my
Try to uninstall one more time. Use disk clean up in Start>accessories>system tools>disk clean up>Select drive>C: click ok for all users. Then restart you computer. Go to C: drive from your computer and look for the program and delete it. Then reinstall the program. If you need more tools download a registry cleaner but what I just explained has to fix it. A good cleaner is ccleaner and it is free from filehippo.com. Remember you can only use the cam for one program at a time when you PC is running.
Hope this gets you going and thanks for using FixYa.
How to make an slideshow
Two methods for you to make a slideshow:
1> save your PowerPoint file as slide show:
Before you save your PPT as PPSX format you need to set up the exact time duration for each slide so that it can run by itself. For more details, please click
How to Timing Automatic PowerPoint Presentations.
Then you should place the presentation file and the music together in the same folder, zip it and send to the recipients.
2>
convert your powerpoint to Flash No sound or any other effect gets lost with both converters. Then email the video presentation or put it on YouTube so that they can share.
6/15/2021 7:05:47 AM •
Arcsoft...
Answered
on Jun 15, 2021
