20 Most Recent
Adobe Systems Adobe AIR Questions & Answers
Adobe plugins
If you are using a recent version of IE, in Manage add-ons, under "Show", select "all add-ons". Maybe it will be in there. Some add-ons are not active until they are required.
When I try to install an add-on for flight simulator from the company Just Flight, this is the error message that shows up about the Adobe air installer that is used to install the add-on:'The app
You might uninstall adobe air restart your computer then run the chkdsk utility Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart You might only tick in the one box to automatically fix files have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive.This might take some time depending on the size of your Hard Drive and the amount of data on it be patient.http://download.cnet.com/jetclean/3000-18512_4-75627788.htmlJetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Then reinstall Adobe Air right click on the program select run as administratorhttp://download.cnet.com/adobe-air/3000-2383_4-10652806.htmlHope this helps
Reinstalling Adobe AIR
You can just click on 'Start', click on 'control Panel', the 'add or remove programs, or for windows 7 ( 'uninstall program'). It will provide a list of programs on the computer, look for Adobe AIR,, click on it and click the button either 'change/remove' or 'delete'. Once ADOBE air has been successfully removed, go onto the adobe website and install the latest version of adobe AIR. Hope this helps.
Adobe air installer not working
Right click on the program select run as administrator.If you want to know what this is the error code is related to Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details Hope it helps.
I had http://www.adobe.com/go/getair but i lost it
I just downloaded adobe.com/go/getair latesst version, but I use it , they said I need that software. When I download again, it says I already got that in my computer. So how I can execute this software. Thank you.
