20 Most Recent
Broadcom Ultimate Low Cost Bluetooth 2.0+EDR USB dongle Questions & Answers
Bluetooth peripheral deiver for hp compaq
If you don't have a build-in Bluetooth in your laptop, then you can buy a USB Bluetooth adapter. It is available at eBay.com or Newegg.com, or at local computer store.
If you have an internal Bluetooth, please let me know your laptop's model.
3/6/2014 7:26:33 AM •
Broadcom...
Answered
on Mar 06, 2014
Wants to change admin password
If you can't access the router because you don't have the password:
Typically, wireless routers have a reset button hidden on the back.
You must depress the button and hold for a min. of 8 secs. When the router is reset, you can use the factory default password. Usually "password". You can enter setup. '192.168.0.1' go into the config and change the password.
11/25/2013 3:31:36 PM •
Broadcom...
Answered
on Nov 25, 2013
Change password
11/25/2013 3:30:23 PM •
Broadcom...
Answered
on Nov 25, 2013
Dell dimension 4700
have you try disable your firewall? windows firewall / antivirus firewall (do not disable your antivirus!) just disable the firewall one by one and try again on difrent usb ports, are you using administrator account to install this ? good luck :)
8/7/2013 3:19:25 AM •
Broadcom...
Answered
on Aug 07, 2013
Device cannot start code 10
I have seen that sometime (especially after a reinstall) the wrong drivers get installed.
- Firstly i suggest going to: http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php and finding the make and model of your network adaptor and update it using the latest driver from that website
- Or you can try and see if your computer manufacturer, be it DELL, Toshiba etc.. has drivers available for your machine as well and get it from their site.
Try each solution and if it asked you to restart once you install the new drivers make sure you do. Any problems let me know.
5/31/2013 11:14:51 AM •
Broadcom...
Answered
on May 31, 2013
Got an acer aspire 7745G
I have the same laptop with the same issue. I had it fixed last year by fiddling with some settings but after a PC crash, its back.
My approach is:
1) install the newest driver (there is a 5.100 version out which did the trick last time)
2) go to start and type services and enter to see all your services. Look for "computer browser" and "TCP/IP Netbios" and make sure they start automatic. This makes sure they restart when it freezes up. When my card disconnects, i get connectivity back in 40 sec.
3) make sure your adapter settings indicate that the computer should not shut down the card to save power. This seems to work for a lot of people.
My solution isn't 100% bulletproof as i'm still trying to figure out how i fixed it last time but these things should get you going. If you google "Netbios has stopped", you'll find that we're not alone with this problem
5/24/2011 10:48:17 PM •
Broadcom...
Answered
on May 24, 2011
