Driver files can be found at
btjunkie.org this is a place I go and get them. If you need future drivers. More than likely you can get the mother board drivers from your disc set provided for you at the time of purchase if you kept them.
You will also need utorrent software as well it is free to download get the software here.
Click Me go to the search box type in drivers use this example, XP drivers. There are lots of them you can put on one disc and then insert the burned disc with the downloaded driver files in the ROM drive and point to the driver that has a highlighted yellow triangle or a question mark in DEVICES window which can be found in the control panel or right click on my computer then have the disc ready to be pointed to find the driver during the update driver files link RIGHT CLICK to access the driver update options.
I have used the 700,000 or the 50,000 or any one of the large files of drivers and have been able to repair computers for folks that do not have driver discs that came with there computers. It has never failed me.
You might run into an .ISO which is an image file to download some drivers get the MAGICISO software program at btjunkie.org.
This should enable anyone to find drivers that are hard to find. Use as last resort. Try to use your original discs first or order a lost restore disc makes life easier when installing programs into your personal computer. You may also use paid for Driver update software as well these work pretty well and not to expensive which saves you lots of time and efforts as well. I use driver genius as one of my main programs you can also find this at btjunkie.
Thanks for using FixYa for all your questions. Do not forget to vote for me as well if I helped you. John
