20 Most Recent Acer Audio_Realtec_WinXP,VISTA_5423_PG233_ACER.zip Questions & Answers
If i open to solve sound problem in sound
It might not be the right driver for your model computer.
Try using a driver finder program to locate the exact sound driver required.
10/17/2010 11:42:59 AM • Acer Audio... • Answered on Oct 17, 2010
Forgotten password
I use a program called "locksmith" which is included on a "commander disk" that I have.
you can check at :
http://www.bootcd.us/ERD_Commander_2003.php I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
4/23/2024 9:24:47 PM • Acer Computers &... • Answered 14 hours ago
My new-bought Acer Aspire 3 has yellow acer logo when starting up, is it normal? Because in some yt videos, the acer logo is green
Perfectly normal. It depends on the internal timing of the GPU and the OS version.
4/17/2024 3:01:26 AM • Acer Computers &... • Answered on Apr 17, 2024
tip
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
2answers
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER. this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done. Acer X1110 data projector Standard throw projector.. did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2) did you read owners manual page 32 yet, errors. LED codes.? there are 4 LED, and all 4 matter, projector turned (ON) (not one =1) also in pairs glowing and also if blinking or not, so read page 32 it tells all that. my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,. color-undefined-undefined-0.jpg https://manualzz.com/doc/49497108/acer-x1110-user-manual some have dust filtler a shop first cleans is out first, and check fan RPM with and LED tachometer. this is all SOP.
4/2/2024 4:37:58 PM • Acer Computers &... • Answered on Apr 02, 2024
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
1/25/2024 8:38:32 AM • Acer Computers &... • Answered on Jan 25, 2024
Gud day my motherboard model is acer b25h4-am pc i forgot the password in bios so i decided to clr_cmos jumper and take out the cmos battery to clear the password of my bios,
I would try starting up and go straight into the BIOS. Set up your system and reboot.
1/23/2024 7:25:53 AM • Acer Computers &... • Answered on Jan 23, 2024
2answers
I can't use bluetooth on my Acer Aspire 7520
This computer does not have Bluetooth capabilities and you can't make it, by adding a Bluetooth Driver. It would need a Bluetooth transmitter and receiver HARDWARE built into the computer at the time of manufacture.. https://icecat.biz/en/p/acer/lx.akg0x.146/aspire-notebooks-aspire+7520-6a2g16mi-1376542.html and this site actually says it. https://www.bhphotovideo.com/c/product/538918-REG/Acer_LX_AN20X_017_Aspire_7520_5757_Notebook_Computer.html/specs Wireless Wi-Fi: 802.11b/g Bluetooth: None ..
11/27/2023 12:05:13 PM • Acer Computers &... • Answered on Nov 27, 2023
Acer 7240 turns off when unplugged
bad battery
10/21/2023 9:29:10 PM • Acer Computers &... • Answered on Oct 21, 2023
CCFL Laptop Screen Inverter
If Laptop is ok and screen is ok then I suggest check the ribbon cable connectors. Are all wires ok ? For information, CCFL Service manual is here https://clubelectronicos.com/wp-content/uploads/2020/11/lg_inverter_t-con_board_repair.pdf and Acer Aspire 8930G Service manual is here Acer Aspire 8930G Service Manual (Page 107 of 119) ' ManualsLib
10/18/2023 1:07:27 PM • Acer Computers &... • Answered on Oct 18, 2023
2answers
Hi could you please tell me if there is caps lock illumination , on ACER ASPIRE 3 LAPTOP. Thank you.
Most laptops have a tiny lamp that illuminated the Caps Lock and Num buttons. These are used to remind the typist they are locked and for error messages when the motherboard won't start properly.
7/28/2023 6:35:14 PM • Acer Computers &... • Answered on Jul 28, 2023
I need another cord connrcter to my acer apiire 5, what is the replacement number thx
google acer aspire 5 power cord there are several sites that sell emplacement cord.
7/22/2023 9:00:19 PM • Acer Computers &... • Answered on Jul 22, 2023
HAVE AN ACER 315 CHROMEBOOK - BROKEN SCREEN HOOKED UP A COBY LED TV 1526 MONITOR- DISPLAY ON THE MONITOR TOO LARGE. HOW CAN I REDUCE THE DISPLAY SIZE?? ctl/shift - does not work.
Settings are done from the computer / Settings / Display / Screen Resolution. It will be trial and error to get it right but try this from the Television Specs 1366 x 768. https://d1vofmza27mmhi.cloudfront.net/product-pdf/coby-ledtv1526-quick-specs.pdf Better to just fix the Chromebook. ..
5/16/2023 4:42:36 AM • Acer Computers &... • Answered on May 16, 2023
HAVE AN ACER 315 CHROMEBOOK - BROOKEN SCREEN HOOKED UP A COBY LEDTV1526 MONITOR- DISPLAY ON THE MONITOR TOO LARGE . HOW CAN I REDUCE THE DISPLAY SIZE??
How do you fix an oversized screen on a Chromebook? Make everything on your screen bigger or smaller
  1. Make your screen bigger, decrease resolution: Press Ctrl + Shift and +.
  2. Make your screen smaller, increase resolution: Press Ctrl + Shift and -.
  3. Reset resolution: Press Ctrl + Shift + 0.
5/11/2023 5:58:34 PM • Acer Computers &... • Answered on May 11, 2023
Acer Predator No Bootable Device. Won’t select on Boot Menu. Stuck with “1. Windows Boot Manager”
Your windows is laod but you can try to restart your computer software and try than,
4/21/2023 2:53:31 AM • Acer Computers &... • Answered on Apr 21, 2023
Acer Aspire One D270 where is BIOS chip located on the motherboard?
Question edited to throw some CAPS at it! Here is the Service manual for it. https://www.manualslib.com/manual/1055939/Acer-Aspire-One-D270.html Strange motherboard! There are no identification pages anywhere. https://www.google.com/search?q=acer+aspire+one+d270+motherboard ..
4/3/2023 7:35:34 PM • Acer Computers &... • Answered on Apr 03, 2023
2answers
Acer aspire acc 603g uw30 turns on but turns back off. Help
This issue could be caused by several factors, including:
  1. Overheating - check if the laptop's fan is working and if the vents are clear of dust and debris.
  2. Low battery - if the laptop is not plugged in, try charging it.
  3. Corrupted software - try performing a hard reset on the laptop or booting into safe mode and running a virus scan.
  4. Hardware failure - if none of the above solutions work, the problem could be a hardware failure such as a failing battery or a damaged power supply. Contact Acer Support for further assistance.
3/3/2023 10:14:46 PM • Acer Computers &... • Answered on Mar 03, 2023
Computers & Internet Logo
1 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • Acer Computers & Internet
Most Popular Question
open solve sound problem in sound
  • Computers & Internet
