20 Most Recent Albatron LWX-30AMS-3 30 in. HDTV-Ready LCD Television Questions & Answers
Firstly, try changing the batteries. If you've already changed then the remote has probably lost the TV code.
If you can post your exact Alba Model number, I will post the correct code and programming instructions for you.
It would also be useful if you can post you Sky remote version number - it's on a sticker in the battery compartment. I need to know if it's Rev 8, Rev 6, Rev 4 or just RC1600/00.
Albatron... | Answered on Oct 16, 2010
When you try to turn on does the tv light indicator, blink in sets? If it does that means you have blown lamp. You can even replaced just do a model search on your telvision and typed in lamp. There should be a part number for your lamp to order. Be careful ordering that, because there are website that well sell you refurbish products.
Albatron... | Answered on Dec 17, 2009
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Albatron... | Answered on Jul 27, 2016
Use the input button or menu button to change the input to cable.
Albatron... | Answered on Nov 30, 2013
my dvd combi works fine but only plays the dvds in black and white and the dvd part of the remote doesnt work
Albatron... | Answered on Jun 11, 2012
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section. Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multi-meter to check the continuity or shorting in components, if so detach from circuit and test. If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly, the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Check for tips to check the SMPS unit:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Albatron... | Answered on Jan 20, 2012
This issue is related to a power problem in as much as the TV turns off on it's own.
The problem is consistent with overheating on the power supply board of the TV. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby making it to misbehave.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.
When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.
To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply board
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board from www/shopjimmy.com to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't have the ability to read the fault, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Albatron... | Answered on Jan 05, 2012
I've posted a clarification request above. You need both the TV model number and the version number of the Sky remote to find the correct code. I install satellite systems - I have access to the entire code database for all versions of Sky remote.
Televison &... | Answered 4 hours ago
Albatron LWX-30AMS-3 30 in. HDTV-Ready LCD Television Logo
Popular Tags
7 questions posted
Top Albatron Televison & Video Experts
Ekse
Are you an Albatron Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Albatron Televison & Video
Most Popular Question
tryin progam sky remote tv got 32in
  • Televison & Video
