20 Most Recent
Anchor Audio/PA Systems: Liberty Sound System Package Microphone Questions & Answers
Not a microphone problem..
my
My personal suggestion would be to go for these repair catalogs. I know this website reliable-store.com that i used to buy them from, and they have online it
was very good manual. Go ahead, I bet.
How to open anchor audio liberty speaker system
As I remember the Anchor has a removable metal back plate that is used to mount the volume control and 1/4" or XLR connectors. Before you start disassembling the unit....are you a qualified repair person? Other than a bad speaker, broken wire or connector there's not much "user servicable" parts inside.
I have power to the
Hello
i assume your running through some kind of mixer.First mark all the microphones or intruments on the mixing board...mic 1 mic 2 guitar 1 whatever your using identify it.Use masking tape and a black marker.
Next.try 1 microphone say #1 mic.Check that the mute button is not down or any presets such as echo or reverb are running through input #1.
Maybe you have a main volume on the board that is turned down? The power amp also needs to be turned up.
From what you have said it could also be a miswiring from the power amp to the board,recheck your input and output from amp to board.
Cant get signal or sound on wireless speakers.
you should be looking for the audio out socket from the tv as the signal is going out from the set to your speakers the other sockets are for input when connecting dvd or video into the tv. hope this helps ..A
How do you replace a battery in an Anchor Liberty
Here is the link to the manual if you don't have one:http://www.google.com/search?hl=en&q=Anchor+Liberty+4500+PA+system+battery+power+replacement&btnG=Search&aq=f&oq=&aqi= It appears as if you have to remove the entire control panel to replace the two batteries. You probably have to use exact replacements. THe link to the company is in the manual and they can probably give you more information. Hope this helps.
