20 Most Recent
Dell Photo 926 All-in-One Printer Questions & Answers
My scanner is plugged in but when I try to scan a document it says my scanner is not responding
Hello,If it is your first time using your printer, then you need to install the driver for it to work. If you have used your printer without any problem before then, there are two possible reasons why your printer/scanner is having that issue:1. Connection error2. Driver problemFirst thing's first. Restart your computer and your printer. there are times that computers and printers just need a restart for it to work. Yes, it's strange but it's how things work with machines. They need rebooting to work smoothly. If rebooting your computer and printer won't fix the problem. Here are the things that you can do.1. Connection error:.a. Turn off your printer and turn it back on. Try scanning, if no go.. proceed to step b. b. Unplug your printer from your computer and unplug it's power cord and press and hold the printer's power button to 5-8 seconds to completely drain the power. Plug it back in to the wall outlet leaving the connection between your computer and the printer still unplugged. wait until your printer completely turns on. Plug it to your computer and do the scanning process. If all steps above don't work, then you need to check the driver.Uinstall the driver of your computer by going to the control panel. After uinstalling it, then reinstall it by using the dvd that came with your printer. Follow the on-screen instructions and try scanning. It should work. If it doesn't, please reply to this thread.Thank you for using fixya.comCarlo Adrian
How do i get my pc to initialize my printer
Hi Toby
Usually you can get the PC to automatically detect your printer by going to Control Panel->add new hardware and the wizard will detect it for you. If you have an installation CD that came with the unit, put it in your CD reader when prompted.
-Steve
How to unpause my printer
There iis usually a good reason printers pause: out of inf, out of paper...There should be an icon at the bottom right of your screen that looks like a printer. Click on it to open the printer services app.
My printer will print one page and stop printing in the middle of the second page.
I think you are seat only one print one time so plz check it. Go to printer option and setting. One time you check printer after your printer which mode show like active print mode, print error, hold print mode etc.
I suggest you Full uninstall printer driver and re-again install printer driver. If not solved then change printer cable.
If more help contact Dell printer Support Technician. and TechSupportPrinter expert team.
Thanks.
Need to clear everything out of the printer queue then uninstall &reinstall the printer & driver
Open Printers and Faxes. Open printer. Highlight jobs and Right click > Cancel, or Documents > Cancel.For those stubborn jobs, Right click My Computer > Manage. Choose Services and Applications > Services > Print Spooler. Right click and stop. Then start.Delete the printer from Printer and Faxes to uninstall. You should check Add remove programs for any printer software. Windows will install automatically with a refresh or reboot. Or, use software that included with printer.
Have the photo 926 printer, can't click on save an image on my computer
if you have a printer scannerlift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it and what format browse select the file/folder where you want to save it (my pictures) most commoninternet search facebook login
once logged in in the left hand corner on the facebook homepage you will click on edit my profile then on profile picture which you can remove
across to the right you will see a browse tab where you can browse to your new photo to upload
hope it helps
