20 Most Recent ASUS EAH5450 SILENTDI1GD2 graphics adapter RADEON HD 5450 1 GB PCI Express Video Card Questions & Answers
www.ati.com drivers / downloads. Asus does not make drivers for their cards. Ati does.
ASUS EAH5450... | Answered on Sep 08, 2011
Either the monitor or the video card have failed. Try another monitor to find out which and replace the failed component.
ASUS EAH5450... | Answered on Aug 29, 2011
is it properly installed? try to boot on the safe mode first and let the windows detect and install it first.
ASUS EAH5450... | Answered on Jul 11, 2011
The easiest thing to try is change the screen resolution before connecting via HDMI. The process is a little different depending on what operating system you're using.
For Windows Vista/Windows 7: 1. Right click on your desktop and select "Screen Resolution" 2. Slide the bar to change the resolution to either 1024x768 or 1280x1024. 3. Click apply.
For Windows XP: 1. Right click on your desktop and select "Properties" 2. Click on the tab to the far right that says "Settings" 3. Under Screen Resolution, slide the bar to change the resolution to either 1024x768 or 1280x1024. 4. Click apply.
Either of these resolutions should at least give you picture when you reconnect with HDMI. Once you get a picture, repeat these steps and gradually move the slider higher to get a better resolution picture. If you receive the incompatible signal message again, just wait 15 seconds and the previous setting will be restored.
If this doesn't work, you may also have to adjust the screen refresh rate. From the same window that has the screen resolution adjustment bar, click the link or button that says "Advanced." The second tab, "Monitor," has a drop-down menu to adjust the screen refresh rate. Depending on your HDTV, the most common setting for this could be 60 Hz, 70 Hz, or 120 Hz. If none of those values work for you, you should check the manual that came with your TV to check what the proper resolution and refresh rate should be for your computer connection.
ASUS EAH5450... | Answered on Jun 10, 2011
If the pc works with another video card then the one you just bought is defective - take it back and have it replaced.
ASUS EAH5450... | Answered on Apr 26, 2011
Hi ,
You are probably facing a power supply issue , though this device isn't exceptionally gready in power consumption .
You will need to replace the PSU by a larger one . 450 Watts will do but don't hesitate to go for a 600 W since these units are fairly cheap .
Best regards
fanaudi
ASUS EAH5450... | Answered on Apr 22, 2011
follow this link
http://www.downloadatoz.com/driver/item_271100.html
please vote
thanks
ASUS EAH5450... | Answered on Apr 15, 2011
useing only ddr3 support
ASUS EAH5450... | Answered on Apr 03, 2011
Hello there, I am the Expert that will be helping you today, my name in damnor01.
Welcome to Fixya.
Your graphics card is overheating and is therefore switching itself off to prevent damage.
Install as many fans as your computer chassis will allow. You need to get some air to flow over the heatsink of this card.
Test this theory by removing the graphics card and then using the onboard Video on your computer mainboard (VGA)
If all is well then it confirms the theory.
However if there is still a problem then we can safely say that it the graphics card is not the cause of the problem.
Use my published guide to download and install the latest AMD Radeon Drivers.
It is entitled, How to install Graphics Drivers, Nvidia and AMD Radeon!!!
You may leave further questions as comments to this solution!
Regards
damnor01
ASUS EAH5450... | Answered on Feb 09, 2011
what is the make of the motherboard you are using?
does the card need extra power supply plugged into the card?
tried another card to see if the new card is faulty?
ASUS EAH5450... | Answered on Jan 18, 2011
You may want to go into safe mode with networking and remove that update then restart the computer and see what it does.
ASUS EAH5450... | Answered on Nov 14, 2010
Hello Peter, If your laptop has the connector, you must use one of them to use a 3.5-mm four-conductor headset with a microphone device, the microphone and headset function can be used at the same time.
Are you thinking about the wireless microphone? It is the other option.
ASUS Computers &... | Answered Yesterday
Please follow this way
Hello Asanka, I don't what's meaning for you like "sewing" is more acceptable ( to understand ) bookbinding.
I understand that my cinema-P7131 is used to enjoy Analogic TV on the PC, also other recording options, listen to music; to edit photos you need a photo editor, such as Movavi Photo Editor, inPlixio Photo Clip and many more!
I leave the links ... enjoy!
1) https://downloads4pc.com/movavi-photo-editor-free-full-version-download
2)
3)
ASUS Computers &... | Answered 2 days ago
When did you begin to notice that they had a problem?
what's going on?
Did you check the measurements of the FxS?
In case that is the problem I leave a video, try to change some values in the registry console so that the problem can be solved.
Download Malwarebytes to a thumbdrive on another computer, insert the drive on your infected computer then run the program.
Make sure the router/modem is connected to the internet; sometimes you just need to shut them down and restart.
ASUS Computers &... | Answered 3 days ago
Need to closed application properly. Go to the task manager (right click on task bar and select task manager) and check in application task if there is any program running also check Process tab and ed task the application related to webcam. Hope this will fix the webcam issue.
ASUS Computers &... | Answered on May 20, 2019
ASUS EAH5450 SILENTDI1GD2 graphics adapter RADEON HD 5450 1 GB PCI Express Video Card Logo
Popular Tags
13 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
update latest driver asus
  • Computers & Internet
