20 Most Recent RaidMax Tornado ATX238WRP Black SECC Steel ATX Mid Tower Computer Case 450W Power Supply Mail In R ATX MidTower Case Questions & Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be
faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need power and data travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all power and data leads make sure they have secure dust free connections
cd/dvd floppy drives need to have current go through make sure these drives are working
check you CPU make sure its securely seated and has thermal grease
hope this helps
RaidMax Tornado... | Answered on Jul 10, 2012
Make sure you have the 4/6-pin 12-volt power connector attached to your motherboard from the power supply in addition to the normal power bar.
RaidMax Tornado... | Answered on Apr 18, 2011
I once had something similar happen to me. Triple check to see that all connections are secure to the motherboard - a loose 20 pin ATX cable was the culprit in my case.
Hope that helps. Good luck!
RaidMax Tornado... | Answered on Mar 02, 2011
sounds like u didnt install the connector on the right place.read the mother board very closely it has a diagram usually in tiny letters
RaidMax Tornado... | Answered on Jan 25, 2011
Test the PSU. Unplug it from the motherboard and then with nothing connected, short the green wire to any ground (usually a black) using a paperclip and it should come on and stay on if the problem was with the motherboard/computer but if it shuts down, then you know the problem is the PSU itself.
If the PSU stays on under no load, then one possibility is you had too much connected to it and it shut down as a protective feature. The Bios would not beep if the PSU is shutting itself down. Also make sure you have the internal speaker connected. It's possible you just can't hear the beep because there is no speaker connected or it may be connected to the wrong place.
Don't throw away a defective power supply. It is worth a couple bucks as parts for an electronics enthusiast. Keep it out of the landfill.
RaidMax... | Answered on May 08, 2015
All new power supplies have a voltage sensing circuit. they need to have a load on them to start.
RaidMax... | Answered on Oct 16, 2013
unplug the orange cable on the motherboard leading to the dvd-rom and replug it into any of the next available slots(2 or 3).
one of them is white in colour and you have to look closely to see the numberings.
problem is sloved.enjoy.
Computers &... | Answered 18 minutes ago
RaidMax Tornado ATX238WRP Black SECC Steel ATX Mid Tower Computer Case 450W Power Supply Mail In R ATX MidTower Case Logo
Popular Tags
5 questions posted
Top RaidMax Computers & Internet Experts
Alun Cox
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • RaidMax Computers & Internet
Most Popular Question
won 39 t power
  • Computers & Internet
