20 Most Recent Vizio High Definition Sound Bar Questions & Answers
After much research, here is a step-by-step for getting your Vizio Soundbar to work with the Comcast remote using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144 (2 blinks)Aux - Setup (2 blinks) - 994 - Setup - 00169 - Vol Up - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00168 - Vol Down - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00037 - Mute - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00165 - Power - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use them:Aux - Setup (2 blinks) - 994 - Setup - 00036 - <button to use for TVOL> - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
Vizio High... | Answered on Feb 01, 2019
I have a Charter Universal Electronics OCAP 4 remote Control and a Vizio VHT215. I was able to get on/off and volume control functionality using code 32454 for the Aux device.
Vizio High... | Answered on Mar 04, 2017
The X-box and Vizo will have sound settings controls. You need to make certain that the optical inputs and outputs are selected on both.
Vizio High... | Answered on Dec 29, 2016
How do you reset bar from Bluetooth . It will not get sound ?
Vizio High... | Answered on May 08, 2016
Please consult any doctor immediate. Don't be late. Take care.
Vizio High... | Answered on Apr 07, 2016
If you get a Vizio sound bar it comes with its own remote control and is, therefore compatable. If however, you want to control all of your electronic devices with one control, instead of searching for the particular codes just spend some small amount on a universal remote unit which has instructions that come with it that show you how to have the remote find and store codes for a whole bunch of devices including the sound bar!
Vizio High... | Answered on Dec 27, 2015
A few things to try:
1) Make sure Batts. are in correctly.
2) check in all around the sides back and under the sound bar for a reset button.
3) Clean the IR emitter on the remote and the receiver on the bar. On the remote it will be a reddish plastic window or a small bulb looking thing on the front. The receiver may be harder to find. I suggest just giving the entire front of the sound bar a good cleaning. I have had remotes stop working because there was to much dust built up on the receiver. I have also found that my kids handled the remote with dirty fingers and had gotten peanut butter on the emitter! Good Luck!
I thought these sound bar gadgets, were designed to produce the full 5.1 effect, so the satellite speakers would not be required. Never liked the idea of these things, if you have the room, to accomodate a full 5.1 system, then go with that.. If you have space limitations, a sound bar if a good compromise
Vizio High... | Answered on Jul 20, 2014
Vizio High Definition Sound Bar Logo
53 questions posted
Top Vizio Audio Players & Recorders Experts
Marvin
Marvin
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Audio Players & Recorders
Most Popular Question
get vizio soundbar programmed charter
  • Audio Players & Recorders
