20 Most Recent
Audio Technica AudioTechnica ATR20 Uni VocalInstrumental Microphone Questions & Answers
Accesssory agents universal codes for techika tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
I have no sound on my technika tv
check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
How to connect external speakers to technica tv
If they're just basic speakers from a stereo system, then you can't connect them directly. The TV doesn't have the sockets nor the power to drive them. You need an amplifier.
For stereo PC speakers, if the TV has a headphone jack socket then you can use that. If it doesn't have that socket, then you'll need to use the TV's optical connection on the back of the TV with an optical to analogue converter box. Amazon does the Cable Mountain box for under 10 quid. This will convert the light signal in to an electrical stereo signal that the PC speakers will understand.
One issue going for PC speakers is that they rarely come with remote control. The volume can't be controlled via the TV's optical out. So you'll have to get up and change volume from the speaker's control instead.
