20 Most Recent
Clarion DXZ438R CD Player Questions & Answers
Varied mode
Go in to the settings and find it and disable it.
Hi, Can you please help
Take out the face (it pops out) and the plastic frame around it - it's hold in there with clips: twist it to disengage the clips and gently pull it out progressively. Once the frame is out the release spaces appear on the sides - press in there 2 flat pieces of whatever (you will feel when the safety pins will be disengaged) and pull the unit out
Error code 6 & error code 4
hi try first to insert a clean up CD, and test your Cd player with an original CD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
sserpentio
Eject
If you remove the deck, turn it upside done it is likely you will see a piece of clear plastic that holds the gear assembly together. usually fractures at the back of the deck where a screw go's through. if this is the case let me know & i will advise how it can be repaired..
Clarion DXZ438R
merce ..measure your din size of radio..width and height..also take notice of the locking mechanism on your radio..draw a quick sketch of it so you can take to a car audio place .they should be able to tell what one fits,
P code for a Clarion cx501
If the radio is a factory radio, the code to unlock it should be on a business card size piece of paper with the owners manual and warranty booklet. The card will say radio code and have a six digit number.
Nissan PP2449H wiring diagram.
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery PINK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground GRAY (-) RADIO HARNESS
THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS.
Illumination RED/BLUE (+) RADIO HARNESS
Dimmer RED/YELLOW (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) BLUE
RF Speaker (+) WHITE
RF Speaker (-) BLACK
LR Speaker (+) LIGHT GREEN
LR Speaker (-) VIOLET
RR Speaker (+) BLUE
RR Speaker (-) PINK
Steering Cntrls NO
Speed Cntrl NO
This listing is for a 2004 Frontier
__________________
