20 Most Recent
Clarion XMD1-RET CD Player Questions & Answers
How to remove clarion xmd1
It's Memorial Day; if somebody didn't tell you or you figured it out, the 2 caps on either side of the unit just snap off. That gives you access to the screws in front. Open the CD compartment to make it easier to get hold of them.
I need the wireing diagram
As long as you haven't cut the wires in the dash of the vehicle, all you need to do is purchase the appropriate wiring harness for the model of car you are installing into. That harness will match perfectly to the Clarion's harness (i.e; red to red, purple to purple, etc..). If you HAVE cut the vehicles wiring, it's a LOT more work. What kind of vehicle are you installing into?
I have this radio on a 2001 sea ray boat with the
I know this isn't going to help you but I have a similar issue. The remote will function IF I first turn on the radio from the radio unit itself. Yours should turn on when the boat turns on, as mine did once. Now, my remote will not turn on the radio but will control it once I take the step mentioned above. I suspect I have a faulty remote. Coincidentally my battery now loses it's charge after a couple weeks of no activity. Perhaps a short in the remote unit causes a slow drain.
Just got a clarion xmd1 but the wires are cut off
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
