20 Most Recent Microsoft Windows XP Professional x64 Edition for PC Questions & Answers
Normally ,windows give this error when some .dll file is missing...
I think better solution is to repair you windows XP using installation disk.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com
Microsoft... | Answered on Jul 18, 2017
if you go to..
zyxel.com support and downloads you can find the latest firmware and drivers for your device. also user guides if yours missing.
you can also use the contact us (top right) to contact tech support for assistance.
sorry not much help
Microsoft... | Answered on Feb 07, 2014
Right click on the Tool Bar (any where below the URL window) and find Favorites on the popup-menu and select it/click on it and it will automatically check Favorites. Once that's done Favorites will show on your Tool Bar.
Microsoft... | Answered on Nov 25, 2013
Code 24This device is not present, is not working properly, or does not have all its drivers installed. (Code 24)Cause
The device is installed incorrectly. The problem could be a hardware failure, or a new driver might be needed.
Devices stay in this state if they have been prepared for removal. After you remove the device, this error disappears.
Recommended resolution
Remove the device, and this error should be resolved THIS MAY BE WHAT U NEED IF NOT THEN SORRY
Microsoft... | Answered on Sep 08, 2012
How to remove an installed program in Win XP
To remove a program that is installed on your computer, follow these steps:
  1. Click Start, click Control Panel, and then double-click Add or Remove Programs.
  2. In the Currently installed programs box, click the program that you want to remove, and then click Remove.
  3. If you are prompted to confirm the removal of the program, click Yes.
Microsoft... | Answered on Jun 28, 2012
Purchase the program...that would be one heck of a crack.
Microsoft... | Answered on Jan 31, 2012
1. shutdown, power-on while tapping the F8 key, boot in safe mode with networking
2. obtain HijackThis from trendmicro.com
3. run and kill those HJT recommends
4. reboot normally
Microsoft... | Answered on Jan 27, 2012
Move and slave the hard disk to a working system and scan the drive for Virus. If no Virus is detected, try and do a repair of the OS with the OS CD/DVD-ROM. If the problem persist, Slave the drive to a working system and reinstall the system.
Microsoft... | Answered on Jan 25, 2012
The problem seems to be conflict in the .dll file "NPSWF32.dll" and it's association with the Windows Registry. The registry key of the flash player for Mozilla Firefox is damaged/corrupted. So you have to uninstall Flash Player: (Follow both the steps.)
Step-1: First uninstall through ADD/REMOVE Programs from controls panel.
Step-2: Then download the Adobe Flash Player uninstaller from here. Now close both Firefox and Internet Explorer. Then run the uninstaller tool. After uninstalling, restart your PC. Now open the firefox and go to http://www.adobe.com/support/flashplayer/ to install the latest version flash player.
Remember: Whenever you are installing or uninstalling flash player you must log on to windows as Administrator to perform and troubleshoot this type of issue.
bcdalai
http://bcdalai.blogspot.com/
Microsoft... | Answered on Oct 26, 2011
Most Fatal errors are due of a device drivers not working correctly, wrong versions of drivers installed or one that has become corrupted due to other program installations or hardware upgrades.
Microsoft... | Answered on Jun 04, 2011
If you are looking for a sound driver software. You can find it here.
http://www.nodevice.com/driver/category/SOUND.html
Just browse your driver and install.
Hope This helps. Thank you for using Fixya!
Microsoft... | Answered on Apr 19, 2011
Simply press the CPU power button and the monitor power button. If windows operating is properly installed in your computer, it will start up.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Microsoft... | Answered on Apr 12, 2011
Try calling microsoft service centre they used to be able to give you an activation code over the phone after verifying your product key
I hope this helps
Andrew.A
Microsoft... | Answered on Apr 02, 2011
Your installation is damaged. This is common. Uninstall it and reinstall it fresh.
Microsoft... | Answered on Mar 17, 2011
Download the respective version from the internet,your file has become corrupt.
Thank You.
Microsoft... | Answered on Feb 13, 2011
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue, and then replace the file. To do this, follow these steps:
  1. Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  2. Type the following command(sfc /scannow), and then press ENTER.
The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
If this could not resolve the issue, Please perform system restore: Follow the steps below, Click on start- all programs- accessories- system tools- system restore.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure below, and then click Next.
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
After reviewing the stability of your system, you can choose another restore point or undo this restoration. Just open System Restore and make the appropriate choice. After you use System Restore, you'll have an additional task, Undo my last restoration, on the System Restore Welcome page. Remember that you'll have to reinstall any programs that were installed after the restore point.
If System Restore doesn't work in Normal Mode, it might work in Safe Mode. To use System Restore in Safe Mode, press the F8 key during reboot and choose Safe Mode. When your computer starts in either Safe Mode or Normal Mode, System Restore can be used to capture a working previous state. System Restore can't be opened unless the system is bootable into one of these modes.
Regards,
Yateesh Varma.
Microsoft... | Answered on Aug 10, 2010
hi,
restart your computer, before your computer will boot up press F9 or delete to access the bios..then choose language settings.
best regards,
kaybicks
Microsoft... | Answered on Feb 23, 2010
Microsoft Windows XP Professional x64 Edition for PC Logo
45 questions posted
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
XP Microsoft
  • XP Microsoft
Most Popular Question
windows xp class not registered
  • Computers & Internet
