20 Most Recent Konica Minolta DiMAGE Z20 Digital Camera Questions & Answers
The following link has a wealth of information about the camera including type of SD card suitable for this model
http://www.imaging-resource.com/PRODS/Z20/Z20A.HTM
Konica Minolta... | Answered on Jun 03, 2014
In the setup menu (wrench logo) first page second line is format.
Click on that and then answer the question Format? with yes.
That is all.
New cards, but also cards used in other cameras, should be formatted, before you start shooting pictures.
Konica Minolta... | Answered on May 12, 2014
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Konica Minolta... | Answered on Aug 13, 2012
Sth mechanical. Refer to a service center and I hope it be still in warranty.
Konica Minolta... | Answered on Jan 07, 2012
Try to format the card either using camera or a PC.
Ensure that your memory card is not a SDHC. Your camera does not support it.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Konica Minolta... | Answered on Feb 01, 2011
To get it to instantly take the picture, you must press the button half-way and allow the camera to lock in the focus (it will beep)...then when the moment is right, press the rest of the way.
Konica Minolta... | Answered on Oct 29, 2010
It could be - or it could be a problem with the PC.
Connect the camera to the pc, go into device manager (right+click on My Computer> down to Device Manager) and see if it is registering a problem.
Delete the camera from device manager (highlight it, press DEL), disconnect the camera from the PC. Power cycle the camera, then connect it back up - you should see the computer finding the camera again.
If not, check a different computer or buy a new cable,
Konica Minolta... | Answered on Jun 29, 2009
Locking mechanism in the card reader is broken and needs service.
Konica Minolta... | Answered on Apr 23, 2009
You're not alone. It's an epidemic. With some people it lasted only about 8 flips between LCD and viewfinder. It's especialy a problem with the Z series. If you still can, send it for repair on warranty, otherwise you'll either have to live with it or find a place that can handle this repair. Good luck
Konica Minolta... | Answered on Aug 29, 2008
I have a Z2 and Z3 and I've never had that problem. I will assume that the batteries are in their proper positions and that the terminals are clean. With this assumption I would suggest you bring it in for repairs. Something w/ the power supply, switch and possibly program, which I don't think us ordinary people can repair. Sorry I can't suggest much more.
Konica Minolta... | Answered on Jul 26, 2008
I would sugest using an adaptor ring. You can reduce the size of your lens opening down a common size lens cap that will fit your camera. If you can't go this route then give me the make and model number and I will see what I can do for you. LJ
Konica Minolta... | Answered on Apr 01, 2008
the problem is with the firmware.
you need to update the firmware of the cam.
you may find the firmware update on the internet on the manufacturers site.
Konica Minolta... | Answered on Feb 15, 2008
I have the same problem, nobody can give me a answer either.
Konica Minolta... | Answered on Feb 10, 2008
we have the same problem.....just started today...on a vacation trip...go figure!?
Can anyone help us here?
Konica Minolta... | Answered on Dec 24, 2007
When I can not see LCD screen when sun shines on it I use viewfinder , I think it tells you in the user Instruction manual if sun is so bright you can not see LCD use viewfinder .
Konica Minolta... | Answered on Dec 21, 2015
Konica Minolta DiMAGE Z20 Digital Camera Logo
22 questions posted
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
View Most Popular
DiMAGE Konica Minolta
  • DiMAGE Konica Minolta
Most Popular Question
transfer memory card computer
  • Cameras
