FixYa.com
NEC MultiSync VT770 Multimedia Projector
All Products > NEC > Multimedia Projectors
Problems with NEC MultiSync VT770 Multimedia Projector?
Search inside NEC MultiSync VT770 Multimedia Projector Knowledgebase
Troubleshooting and Support
Solved Problems for NEC MultiSync VT770 Multimedia Projector RSS Feed Post a New Problem
How do I redirect the output of my PC...
How do I redirect the output of my PC laptop to the projector?
1 Solution
Projection Problem with Toshiba TLP 261
When the projector is turned on, it displays the default screen. In the lower left corner the display is red. Adjusting...
1 Solution
Connecting Sky TV to my projector
I am finding it hard to connect my sky tv to my projector, which cable do i need.
2 Solutions
sharp digital multi media projector PG...
Screen show keeps cutting out for 5 - 20 secs although the projector is still operating and somes back on...
1 Solution
vt45 projector turns off without notice.
The projector turns off while in use. It doesn't really needto be "too hot". It may be in the first few...
1 Solution
In Focus X2 projector won't display...
In Focus X2 projector won't display welcome screen. It turns on, the fan goes on too and the green light is steady. I...
1 Solution
Remote control for Canon LV X6 Projector
I cannot seem to get the remote control to work for the projector. I'm trying to use a PowerPoint Presentation and the...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeLCD Projector
Form FactorPortable
Display TechnologyTFT Active Matrix
Image Brightness3000 ANSI lumens
Contrast Ratio400:1
Max Resolution (Native)1024 x 768
Image Aspect Ratio4:3 (Standard)
Image Size (Diagonal)25 in. - 300 in.
Screen Distance2.3 ft. - 36.09 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1600 x 1200 (UXGA)
Synchronization Range Horizontal15 - 100 kHz
Synchronization Range Vertical50 - 120 Hz
Technical Features
Audio OutputSpeaker(s)
Operation Noise35 dB
Interfaces
InterfaceRS232C (mini DIN-8 pin) · USB
Video Input4 Pin - Mini DIN (S-Video) · 15 pin D-Sub VGA x 2 · Component Video
Lamp
Light Source Life2000 Hours
Other Features
Special FeaturesKeystone Correction · PCMCIA Slot (type II)
Speakers Output5 W
Standards
Analog Video FormatNTSC · PAL · PAL-M · PAL-N · SECAM · NTSC 4.43 · PAL 60
HDTV Formats720p · 1080i · 480p · 480i · 1080p
Warranty
Warranty3 Years
Dimensions
Depth9.65 in.
Height3.82 in.
Width13.39 in.
Weight7.94 lb.
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
