20 Most Recent
Clarion OHM153 15.3 in. Car Monitor Questions & Answers
I bought a toyota and i dont know how too urn on
Go to Clarion .com select united states then select support at the top of the screen. then in the middle you will see installation and operating manual it said use remote for power and fm to play through radio but you need a second part to run Fm modulated but you may already have it . also it has built in wireless headphone IR transmitter. Check web site for purchase of remote and if no luck . check your locals car stereo shops for a clarion dealer and see if they can get remote and ebay last resort.
P code for a Clarion cx501
If the radio is a factory radio, the code to unlock it should be on a business card size piece of paper with the owners manual and warranty booklet. The card will say radio code and have a six digit number.
Nissan PP2449H wiring diagram.
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery PINK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground GRAY (-) RADIO HARNESS
THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS.
Illumination RED/BLUE (+) RADIO HARNESS
Dimmer RED/YELLOW (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) BLUE
RF Speaker (+) WHITE
RF Speaker (-) BLACK
LR Speaker (+) LIGHT GREEN
LR Speaker (-) VIOLET
RR Speaker (+) BLUE
RR Speaker (-) PINK
Steering Cntrls NO
Speed Cntrl NO
This listing is for a 2004 Frontier
__________________
DOES CLARION BD357MP HAVE BLUETOOHT INTEGRATED
No, the Clarion BD357MP car stereo receiver does not have Bluetooth integrated. The receiver was released in 2007, and Bluetooth integration in car stereo systems was not as common at that time as it is now.
However, you may be able to use a Bluetooth adapter to connect your phone or other Bluetooth-enabled device to the stereo. Some aftermarket Bluetooth adapters can be plugged into the auxiliary input of the stereo or connected via an FM transmitter to add Bluetooth functionality. Check the compatibility of any adapter with your Clarion BD357MP receiver before purchasing to ensure it will work properly.
Clarion db185 mp no sound
If your Clarion DB185 MP head unit is not producing any sound, here are some steps you can try to troubleshoot the issue:
- Check the wiring: Make sure that all the wiring is properly connected and there are no loose connections. Check if the speaker wires are connected to the correct terminals on the head unit and the speakers.
- Check the fuses: Make sure that the fuses are not blown. Check the fuse box in your car and make sure that the fuse for the head unit is intact.
- Check the volume: Make sure that the volume is turned up and not muted. Check if the "MUTE" function is activated.
- Check the balance and fade settings: Make sure that the balance and fade settings are set correctly. If the sound is only coming from one speaker, it could be because the balance is off.
- Check the sound settings: Make sure that the sound settings are not set to "FLAT" or "OFF". Adjust the equalizer settings to see if it improves the sound.
If none of these steps work, then the problem could be with the head unit itself. You may need to take it to a professional to have it checked and repaired.
Does clarion m5475 have an aux in jack
I'm not seeing one based on the images that I'm seeing from it's front view. I only see number pads on the right side of the face with and circular arrangement of buttons on the left side of the device. But you can check the back of the device as I see 2 input on the top-right side of the back of the clarion device.
Thank you.
I have a nx604 clarion when it come on the face says intellgence voice then clarion and nothing else
when the voice prompt comes on, please attempt to speak the words "factory reset" and check for any activity. Also, if you haven't attempted to restart your car prior to the first recommendation, please do that first before restarting your clarion equipment again. If those steps fail, you might need to process the factory reset via the equipment without using your voice. If you don't have the proper documentation to help guide you through through the reset process, please reach out to clarion by dialing 877-424-6423.
Thank you.
