FixYa.com
NEC LT80 Multimedia Projector
All Products > NEC > Multimedia Projectors
Problems with NEC LT80 Multimedia Projector?
Search inside NEC LT80 Multimedia Projector Knowledgebase
Troubleshooting and Support
Solved Problems for NEC LT80 Multimedia Projector RSS Feed Post a New Problem
How do I redirect the output of my PC...
How do I redirect the output of my PC laptop to the projector?
1 Solution
The "No Signal" led is displayed...
The "No Signal" led is displayed from the projected image, is it normal?
1 Solution
Projection Problem with Toshiba TLP 261
When the projector is turned on, it displays the default screen. In the lower left corner the display is red. Adjusting...
1 Solution
optoma projector
We are having problems with our projector. The screen (or light bulb) flickers. We have had it just a little over a year...
1 Solution
Sanyo Projector==No signal
Sanyo projector is not registering a signal when connected to a Dell laptop. I followed set-up procedure--first,...
1 Solution
Connecting Sky TV to my projector
I am finding it hard to connect my sky tv to my projector, which cable do i need.
2 Solutions
sharp digital multi media projector PG...
Screen show keeps cutting out for 5 - 20 secs although the projector is still operating and somes back on...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for NEC LT80 Multimedia Projector RSS Feed Post a New Problem
temperature protection
Like the problem posted Aug 10 2005 My projector also will buzz sometimes and the light will not turn on, however...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC · Mac
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness600 ANSI lumens
Max Resolution (Native)800 x 600
Image Size (Diagonal)24 in. - 300 in.
Screen Distance3.94 ft. - 40.35 ft.
Color Support24-bit (16.7M colors)
Technical Features
Audio OutputSpeaker(s)
Lamp
Lamp TypeMetal Halide
Standards
Analog Video FormatNTSC · PAL · SECAM
Warranty
Warranty2 Years
Dimensions
Depth12.81 in.
Height4.81 in.
Width9.77 in.
Weight9.92 lb.
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
