20 Most Recent
NEC LT 260 Multimedia Projector Questions & Answers
WHEN POWER ON PROJECTOR DOES NOT ON WORK
Do you get lights? are they blinking? The number of blinks will tell you what is wrong if you go to the manufactures site and pull up the manual. (It may be a combination of lights instead of blinking lights)
Check for:
Bad bulb-check to see if the little wire inside is whole, just like in a lightbulb, look for cracks near the base, or any other sign of breakage.
bulb- inserted improperly?
All panels and doors must be on, and the screws in, for most projectors to do anything..
Check the cord, you should get at least one light if the cord is good.
Red light blinking in nec lt 260
how many times? that will tell you what's wrong:
1x- lamp cover (close lamp cover)
2x- temperature problem (too hot. clean out and cool down)
3x- power problem (check power)
4x- fan problem (one or more fans not running)
6x- lamp fails to light (lamp or ballast problem)
NEC projector M322X indicates light but cannot turn on
Based on the information provided, it is possible that there may be an issue with the projector's power button or internal components. It is recommended to try the following troubleshooting steps:
1. Check the power source: Ensure that the projector is properly plugged into a working power outlet and that the outlet itself is functioning correctly.
2. Reset the projector: Some projectors have a reset button or option in the settings menu. Try resetting the projector to see if this resolves the issue.
3. Check for internal issues: If the above steps do not work, there may be an issue with the projector's internal components. It is recommended to contact a professional technician or the manufacturer for further assistance.
In summary, if a NEC projector indicates light when plugged into a power source but does not turn on when the power button is pressed, it may be due to issues with the power source, internal components, or other factors. Troubleshooting steps such as checking the power source and resetting the projector may help resolve the issue, but professional assistance may be required if these steps do not work.
