20 Most Recent Tascam TEAC CD-RW890 Digital Cd-R/RW Audio Recorder & CD Player w/ Remote Questions & Answers
Hello Henry, I sent you the link to download the user manual of your Tascam DP2 and see there, what are you looking for
I hope you can solve your need
Greetings Franco Dosil
Hola Henry , te envio el link para que descargues el manual de usuario de tu Tascam DP2 y veas ahi, lo que estas buscando
Espero puedas resolver tu necesidad
Saludos Franco Dosil
https://tascam.com/downloads/tascam/37/E_DP-02&02CF_web.pdf
Tascam Audio... | Answered on May 17, 2019
Hello Donnie, I sent you the link to download the user manual of your Tascam DP2 and see there, what are you looking for
Hola Donnie, te env?o el link para que descargues el manual de usuario de tu Tascam DP2 y veas ah?, lo que estas buscando
Hello Rick, to be able to activate the recording button, you must have placed a cassette, that has the lock to record, this is in the upper part of the cassette and has one for each side, in your case it will have to have the corresponding to the on the side that you use to record
Looking at the cassette in front, with the tape down, the lock is up on the left, if you do not have it, you can replace it with a Scotch tape covering the hole
I hope my comment will serve you
Hola Rick, para poder accionar el boton de grabacion, debes tener colocado un cassette, que tenga la traba para grabar, esta se encuentra en la parte superior del cassette y tiene una para cada lado, en tu caso tendra que tener la correspondiente a la del lado que usas para grabar
mirando el cassette de frente, con la cinta para abajo la traba esta arriba a la izquierda, si no la tuviera, la puedes reemplazar con una cinta Scotch cubriendo el agujero
Espero que te sirva mi comentario
https://upload.wikimedia.org/wikipedia/commons/thumb/0/05/Cassette_Write_Protect_IV.jpg/220px-Cassette_Write_Protect_IV.jpg
Tascam Audio... | Answered on May 08, 2019
Hello Ken, I was looking in the manuals of Tascam 302 and it does not refer to "ERR 1", it appears "ERR 2" and "ERR 3"
From what you describe, you may have a power supply problem in the low signal area, or have some of the mechanisms out of point, so you can see that the axes are turning
If you have technical features, try disconnecting the multipin cable that feeds the mechanics and check if the noise continues, if it does not appear, go reconnecting each mechanism separately and looking for which generates the problem, could be both, at that point I suggest, consult to a specialized technical service
I hope my comment has served you
Hola Ken, estuve buscando en los manuales de Tascam 302 y no hace referencia a "ERR 1", aparece "ERR 2" y "ERR 3"
Por lo que describes puede ser que tengas un problema de fuente de alimentaci?n de la zona de baja se?al, o tengas alguno de los mecanismos fuera de punto, por eso observas que est?n girando los ejes capstan
Si tienes conocimientos t?cnicos, prueba desconectando el cable multipin que alimenta las mec?nicas y verifica si continua el ruido, si no aparece , ve re conectando cada mecanismo por separado y buscando cual genera el problema, podr?an ser los dos, en ese punto te sugiero, consulta a un servicio t?cnico especializado
Espero te haya servido mi comentario
Tascam Audio... | Answered on Apr 24, 2019
I JUST REINCERT THE CART AND SORKED AGAIN??
Tascam Audio... | Answered on Feb 17, 2019
Google (Tascam)(644)(manual) without parens.
Tascam Audio... | Answered on Jan 11, 2019
This is a common oversight by the recordist (you, inthis case). Put the CD back in the recorder, and access the recorder's menu. Look for 'Finalize disc' or Finalize recording'. Select this option, and wait the machine to prompt you to remove the disc.
Finalizing the recording is what encodes the new recording disc to your geographical location's standards. Once disc is finalized, it will play in any playback disc drive in the same geographical region as the one you are in.
Tascam Audio... | Answered on Dec 28, 2018
The unit doesn't run on Windows, so the operating system won't be recognised by a Windows PC. You may be able to find the audio files by using an Undelete program, but it is a guess whether or not it will find them.
The ideal way would be to find a working unit, put your hard drive in and burn everything to CD, then put into a computer and back up to the PC hard drive.
Tascam Audio... | Answered on Dec 08, 2018
Tascam TEAC CD-RW890 Digital Cd-R/RW Audio Recorder & CD Player w/ Remote Logo
2 questions posted
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Tascam Audio Players & Recorders
Most Popular Question
went turn tascam 302 all buzz press
  • Audio Players & Recorders
