I am using a NEC
I am using a NEC data projector for the past 5 years. Recently I have problems in displaying a video(DVD)using...
1 Solution
Lamp not working
I read the solution posted on 8/30/07, but my remote does not have a help button. It's only unique buttons are...
1 Solution
Specifications
Key Features
Display TechnologyTFT Active Matrix Image Brightness2000 ANSI lumens
Max Resolution (Native)800 x 600 Image Aspect Ratio4:3 (Standard) Image Size (Diagonal)20.87 in. - 300 in. Screen Distance2.3 ft. - 36.09 ft. Color Support24-bit (16.7M colors) Max Resolution (Interpolated)1600 x 1200 (UXGA) Synchronization Range Horizontal15 - 100 kHz Synchronization Range Vertical50 - 120 Hz
Technical Features
Audio OutputSpeaker(s) · 3.5 mm Mini Jack Remote Control FeaturesBuilt-in Mouse
Interfaces
InterfaceSerial (RS232) · Infrared Video Input4 Pin - Mini DIN (S-Video) · 15 pin D-Sub VGA x 2
Lamp
Light Source Life3000 Hours
Other Features
Special FeaturesOn Screen Menu · Keystone Correction Projection MethodRear · Front · Ceiling
Standards
Analog Video FormatNTSC · PAL · PAL-M · PAL-N · SECAM · NTSC 4.43 · PAL 60
Warranty
Warranty3 Years, 6 Month on Lamp
Dimensions
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
