user manual
hi i have this new beetel walk clip caller id cordless phone but i do not have the users manual,so i cannot load the...
1 Solution
Specifications
Key Features
Display TechnologyTFT Active Matrix Image Brightness1300 ANSI lumens
Max Resolution (Native)1920 x 1080 Image Aspect Ratio4:3 (Standard) · 16:9 (Wide Screen) Image Size (Diagonal)21 in. - 300 in. Screen Distance2.3 ft. - 36.09 ft. Color Support24-bit (16.7M colors) Max Resolution (Interpolated)1600 x 1200 (UXGA) Synchronization Range Horizontal15 - 100 kHz Synchronization Range Vertical50 - 120 Hz
Technical Features
Audio OutputSpeaker(s) · 3.5 mm Mini Jack
Interfaces
InterfaceSerial (RS232) · Infrared Video Input4 Pin - Mini DIN (S-Video) · 15 pin D-Sub VGA x 2 · Composite Video
Lamp
Light Source Life2000 Hours
Other Features
Special FeaturesKeystone Correction Projection MethodRear · Front · Ceiling
Standards
Analog Video FormatNTSC · PAL · PAL-M · PAL-N · SECAM · NTSC 4.43 · PAL 60 HDTV Formats720p · 1080i · 480p · 576p · 480i
Warranty
Dimensions
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
