FixYa.com
NEC NEFAX-805 Plain Paper Fax
All Products > NEC > Fax Machines
Problems with NEC NEFAX-805 Plain Paper Fax?
Search inside NEC NEFAX-805 Plain Paper Fax Knowledgebase
Troubleshooting and Support
Solved Problems for NEC NEFAX-805 Plain Paper Fax RSS Feed Post a New Problem
My fax unit cannot receive an incoming fax...
My fax unit cannot receive an incoming fax when it is connected to an answering machine. How do I correct this?
1 Solution
"Receiving Sleep" on Brother Fax...
Please help me. Our business fax says receiving sleep, but none of the faxes are coming through. I cannot get it off...
1 Solution
gestetner 9940 help me
my incoming faxing are terribly dirty. How can i clean the toner or what needs to be cleaned??
1 Solution
Connecting additional telephones
I have just purchased this fax machine and i have connected an additional phone to the EXT socket on the fax machine....
1 Solution
Brother TN350 - Toner Problem
The toner in our Brother TN350 Fax machine is leaking and causing the printed copies to be full of ink.
1 Solution
FAX TROUBLESHOOTING
FAX MACHINE ABLE TO SEND BUT NOT TO RECEIVE
Post a Solution
poor line condition error Brother...
andalso the replace drum error won't go away after replacing the drum
2 Solutions
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Paper TypePlain Paper
Fax Print Quality/Resolution
Max Print Resolution600 x 600 dpi
General Information
Auto Doc FeederYes
Tray Capacity250 Sheets
Document Handling
Copy Enlargement200%
Copy Reduction200%
Max Copy Resolution600 x 600 dpi
Memory
Memory, RAM16 MB RAM
Send/Receive Capabilities
Fax Speed33600 bps
Phone Specifications
Speed DialingYes
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
