FixYa.com
NEC Replacment Lamp Projector Lamp for VT470&VT670 - 3000Hrs Eco/2000Hrs Std 180W [ VT75LP
All Products > NEC > Multimedia Projector Replacement Lamps
Problems with NEC Replacment Lamp Projector Lamp for VT470&VT670 - 3000Hrs Eco/2000Hrs Std...?
Search inside NEC Replacment Lamp Projector Lamp for... Knowledgebase
Troubleshooting and Support
Solved Problems for NEC Replacment Lamp Projector Lamp for VT470&VT670 - 3000Hrs Eco/2000Hrs Std 180W [ VT75LP RSS Feed Post a New Problem
NEC VT 470 projector won't work at all
Our school has a NEC projector VT470 and the lamp won't come on at all. It was "dead" when the teacher brought...
2 Solutions
NEC 670 projector
One of the NEC,s at my school has stopped projecting and makes a sound like it want to go on and then shut down (Red...
1 Solution
Ballast Unit
Where's the ballast unit and how do you replace it in an NEC VT470?
1 Solution
my projector keep shutting down
I changed my lamp on a Boxlight 17-K as the lamp incator was on and the projector shutted down. but after I changed my...
1 Solution
Battery Chargers
Hi, I lost my adapter to my battery charger I use to charge my camera with, and I didn't know if it was possible to just...
1 Solution
Replacing Fujitsu lamp
Hello I have a Fujitsu scanner 3096gx and cannot figure out how to replace the bulb. We have the bulb here but there are...
1 Solution
Toshiba computer
I have an older Toshiba I bought back in 2000 that I've updated it up for a friend to use, it was running fine until she...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for NEC Replacment Lamp Projector Lamp for VT470&VT670 - 3000Hrs Eco/2000Hrs Std 180W [ VT75LP RSS Feed Post a New Problem
NEC VT770
i replaced the lame and it still says lamp has has no life
Post a Solution
Tips & Tricks
Post a New Tip
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
