20 Most Recent Korg X5d Questions & Answers
You can try this.
STEP 1:
Set Program protect and Combi Protect to OFF.
- GLOBAL
- Using PAGE+ or PAGE-,
find untill the display show "3A-MEMORY PROTECT".
Set the parameter to OFF by using YES or NO button.
STEP 2:
Data Load.
- GLOBAL.
find untill the display show "05A-PRESET DATA".
Change ALL to PRG (your case).
Use Left/Right Arrow button to moving cursor.
Choose "PRE-a" (your case).
Move cursor to "OK?".
Press YES when "OK" blinking for confirm.
Exit (Go to PROG button).
Korg X5d | Answered on Dec 19, 2017
Download the owners manual from here and try doing a reset to factory settings
http://www.korguksupport.co.uk/page.cfm?pageid=391#Owners Manuals
Korg X5d | Answered on Mar 13, 2016
That sounds like a manufacture date being flashed. Have you checked the battery? If you can't backup first, all your changes (custom sounds) will be lost, but that might be what you are looking at. Replace the battery, or have a service center do so. You'll want to reset after.
Try ROM check first.
Initialization: Hold Page + and Page - while turning it on.
Preload: Global Screen 5A, then select "OK".
ROM Check: Hold Edit and Global/Multi while turning it on.
Guide:
How to Initialize reset and preload on the Korg X5 X5D DR SweetCare
Korg X5d | Answered on Dec 19, 2014
Hold PROG and +10 while turning it on.
That should initialize the unit to factory fresh.
Korg X5d | Answered on Oct 16, 2014
if you do not already use a midi sequencing software try "Bome's SendFX". After installing, go to X5D menu 04A MIDI DUMP, choose data you want do dump (e.g. "all"). Make sure, that no SYSEX FIlter is active while working with a sequencing software.
After transmission, you can save the "yoursounds.mid" file and send it back to the X5D later.
Korg X5d | Answered on Apr 20, 2014
Korg X5d Logo
49 questions posted
Top Korg Music Experts
Michial Gueffroy
Experi
Level 1 Expert
David Gust
Are you a Korg Music Expert? Answer questions, earn points and help others
View Most Popular
Korg Music
  • Korg Music
Most Popular Question
save x5d sounds in laptop
  • Music
