20 Most Recent Sony Bravia XBR-52HX909 52 in. LCD HDTV Questions & Answers
This problem u must play with the tv orignal remote.Look on the tv original remote for a buttons like Aspect Ratio,Picture Sizes,VIEW MODES,ZOOM.Just pushes one of these buttons until u have the desire screen format for u.The screen will jump every sizes,u can't get evrythings u want,have to give and take as the tv pictures exspan or contract.
Sony Bravia... | Answered on Aug 12, 2011
The resolution is controlled by the video sources, you do not adjust it at the TV, if you feed it with video sources that is 1080i it will display 1080i.
I hope that will explain how it works.
Sony Bravia... | Answered on Apr 02, 2011
This tv only a week olds,should never having this problems already.The tv should be return and get a new tv for the replacement,this tv have tv Tuner signal board or tv power supply board distrubution problems.Even when the store test it out it work,don't take that tv back.Insit they give a new tv for the replacement.
Sony Bravia... | Answered on Dec 13, 2010
Hi Sherry, you can test your remote control to see if all the keys work correctly
Take your cell phone, put in camera mode and point the emitting LED of the remote control towards the camera,
press the keys, one at a time and see if the emitting LED is illuminated, if so, try the volume up key, if the light does not turn on, you could carefully disassemble the remote control and clean the contacts and the keyboard internally rubber,
Do not use alcohol to clean
the rubber keyboard, you can clean it with warm water and detergent then let it dry very well,
the contact plate, you can use a cloth with some liquid to clean the glass,
the idea is to remove the rubber residue on the contacts
then arm again and test, but you have results consult a specialized technical service
I hope you find the suggestion useful
Greetings Franco Dosil
Hola Sherry, puedes probar tu control remoto para saber si todas la teclas funcionan correctamente
Toma tu celular, pon en modo camara y apunta el Led emisor del control remoto hacia la camara,
presiona las teclas, una por vez y fijate si se ilumina el Led emisor, si es asi, prueba la tecla de subir el volumen, si no se prende la luz, podrias desarmar con cuidado el control remoto y limpiar internamente los contacto y el teclado de goma,
No Uses Alcohol para limpiar
el teclado de goma, lo puedes limpiar con agua tibia y detergente luego dejalo secar muy bien,
la placa de los contactos, puedes usar un pa?o con un poco de liquido para limpiar los vidrios,
la idea es sacar el residuo de goma que hay sobre los contactos
luego arma nuevamente y prueba, sino tienes resultados consulta a un servicio tecnico especializado
Espero te resulte util la sugerencia
Saludos Franco Dosil
Sony BRAVIA... | Answered Yesterday
hello Dear
this is panel problem please replace panel
Thanks
M Nasir
Sony BRAVIA... | Answered on Apr 14, 2019
Aron,
To perform a reset you will need to disconnect the TV completely from power for at least 30 seconds, if this doesn't resolve your problem then you may have hardware that has expired in your device. Without physically looking at your device I can't say with certainty what your problem is, it could be your PCB. There are video's online you can visit on how to test a PCB for faults.
If you are not comfortable troubleshooting your device I would suggest contacting a local electronic repair shop near you, however I will link you to a generic instructional video showing you how to perform basic troubleshooting of your device.
Hope this helps,
Best regards
https://www.youtube.com/watch?v=qxG3hmmvkJs Testing LCD TV Power Supply BoardsSTEP BY STEP
Sony BRAVIA... | Answered on Mar 08, 2019
Although I am just guessing, most Sony equipment uses metric screws. Go to a Home Depot or similar store and take the piece that you have that contains the threaded fittings and they will help you find the screws you need. https://www.manualslib.com/manual/793567/Sony-Kdl-32xbr6.html?page=7#manual This page of the manual gives some info about the screws such as not longer than 1/2" (or 12mm) to prevent damage to the set. Sony customer service may be able to supply replacement screws too.
Sony BRAVIA... | Answered on Feb 18, 2019
Go to the initial set up procedure and disable it.
Sony BRAVIA... | Answered on Feb 14, 2019
Open internal fuse or power supply failure
Sony BRAVIA... | Answered on Jan 23, 2019
Unplug from wall for 60 secounds then plug back in. See if that works.
Sony BRAVIA... | Answered on Jan 19, 2019
Press the HOME button on the remote control.
Select Settings.
Select System Settings.
Select Customer Support.
Select Factory Settings.
Select OK.
Sony BRAVIA... | Answered on Jan 18, 2019
THe antenna came of. Did you use it and is it giving troubles now? If not, then don't mind and leave it.
Sony BRAVIA... | Answered on Jan 17, 2019
Set the resolution to suit your screen.
Sony BRAVIA... | Answered on Dec 07, 2017
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sony BRAVIA... | Answered on Sep 02, 2017
Sony Bravia XBR-52HX909 52 in. LCD HDTV Logo
6 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
39 ve notice while watching baseball
  • Televison & Video
