20 Most Recent Mtd Arnold Corp No Oem 754 04002 Dr Belt for Mower Questions & Answers
Try setting and locking the brake/clutch.
Mtd Arnold Corp... | Answered on Aug 26, 2011
Your spindle bearings are either worn out or you have a bent blade. Check the blades first. If they are not rubbing on the deck then take the belt off and turn the spindle by hand and see if you feel or hear any grinding noise.
Mtd Garden | Answered on Dec 05, 2018
check out some videos but make sure you order the right part
if no spark to spark plug, most likely coil:
Mtd snowblower 4 5 no spark new coil new plug wire is good switch is good...
Mtd Garden | Answered on Nov 16, 2018
Turn mower on its side and there should be a drain plug on the underside if not get a suction gun and suck it up out of the oil fill tube.
Mtd Garden | Answered on Nov 13, 2018
try SEARS PARTS DIRECT.COM THEY CAN HELP
Mtd Garden | Answered on Oct 28, 2018
If you go to this link and put your model number in it will give you a list of all parts for your mower. This is the side I use to order parts. you may be able to get parts cheaper locally but it will give a complete list of parts available.
https://www.mtdparts.com/equipment/mtdparts
Mtd Garden | Answered on Oct 06, 2018
hi,
usually in the shift selector theres a ground clip thats connected to the ignition, when the metal gearshift touches the clip it dies. disconnect and tape that wire going to the spring clip on the gear selector. if its hydrostatic then you will have to study the gearcase and look for wires going into it. perform at your own risk as mowing in reverse isnt recommended..
Mtd Arnold Corp No Oem 754 04002 Dr Belt for Mower Logo
2 questions posted
Top Mtd Garden Experts
Jim Parker
Jim Parker
lnbn1975
Morne Olivier
Are you a Mtd Garden Expert? Answer questions, earn points and help others
View Most Popular
Mtd Garden
  • Mtd Garden
Most Popular Question
replacing belt 754 04002 mtd
  • Garden
