20 Most Recent
OKI (09002353) Serial Adapter Questions & Answers
Bought a printer server called
- log into router
- look at the leases issued by the dhcp server in the router
- note the ip address assigned to the printer
- change the lease to be permanently leased to the printer server
- the print server will have a device name . you should be able to figure out which ip address is assigned / leased to it .
- You never assign a print server , or server or printer with a temporary dhcp ip address ! hence why you should change the lease of it to permanent .
- Then it will be assigned the same ip address by the dhcp server .
When printing there are black
Please remove and clean the catridges with a soft tissue slightly wet. Leave to dry for a couple of minuites the place back. Goodluck.
No function
Replace the defective power-supply -- there is nothing that an "end-user" can do to fix it.
How do reset an oki
- Turn off the printer.
- Hold down the SHIFT and LF buttons, and at the same time turn the printer back on.
- Release the buttons.
- The printer should be reset to the default settings now.
I've returned home from Spain
On the logon screen press the crtl+alt+del twice till it will give you a window that ask for the username and password, erase the username(if there is) and type administrator no password and press enter. You should be able to logon to the administrator account. If your successful you can change the password of your previous account
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
