20 Most Recent
Liquid Video MVOHD80 Car DVD Player Questions & Answers
Shuts off
it may be over heating may have to replace the small integarted fan.
Low low low sound on mvohd80
Hi Tom
if this is for the jacks located on bottom of screen the remote is the only way to solve this problem search www remotes com they have this remote if you are using wireless headset volume is on headset by power button hope this helps
MVOHD70 DVD player re-installation
Wherever your overhead dome light is, you will be using the wire harnesses appropriate for the connections. The wire connectors will only fit the appropriate connectors. The best way to attach the DVD player to your ceiling is to screw a wooden block (8" W x 6" L, with the length of the block being width) using self-tapping metal screws. There should be a metal cross-member in the ceiling that will permit you to attach the wooden block with the self-tapping metal screws, or you can use a drill to make pilot holes in the metal cross-member and wood, but you will have to make sure that the holes are aligned. Once you have attached the wooden block, you will have to attach the DVD player by opening the screen and finding the screw holes through the main body of the DVD player. You can then use wood screws in the holes to attach the DVD player. If you have any other question concerning this matter, please post here again requesting MTM help.
DVD player keeps shutting off
I HAD THE SAME PROBLEM BUT ON MINE I HAD TO REWIRE THE FAN WHERE IT HAD WENT OUT IT WAS REAL SIMPLE.JUST TAKE THE BACK OFF OF OT AND UNCLIP THE FAN WIRES AND SPLICE THEM INTO THE HOT AND GROUND WIRES THAT RUN RIGHT BESIDE IT (THE MAIN HOT AND GROUND) .IT WAS GOING TO COST ME 85 DOLLARS TO HAVE IT FIXED IT ONLY TOOK ME ABOUT 30 MIN.AND I DID IT MYSELF.GOOD LUCK
I need Parts
Contact the manufaturer directly, or try BestBuy parts on their website. Goodluck.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
