20 Most Recent
Traxxas 110 Slash Truck Greg Adler 24ghz Radio 5803 Questions & Answers
How do i start the truck
Turn on the remote then hold the e z set button on the esc until it lights up then let go the n you drive
The steering works fine but
is your ESC/speed control. Hooked up properly and working? That is what should be controlling your throttle.
Thanks,
Lee
After stopping I try to
According to you your truck not working. So first check the battery cell, replace or change the battery. make sure the battery circuit section is OK and working fine. Check the wheel section also, It may stuck or their is some blockage. If it can't solve your problem then you can rush to the nearest service center.
Vxl-3s velineon problem with speed control
This problem is very common with the traxxas vxl 3-s speed control. If you were previously running it in 70 degrees or above without a cooling fan, hobbytown is correct. If you have a fan, or it is cool outside, try your best to return the speed control for a new one.
5/13/2015 9:11:17 AM •
Traxxas Toys
Answered
on May 13, 2015
