20 Most Recent Lite On LVW-5101 DVD Recorder Questions & Answers
Try this link to download it.
Lite On LVW-5101... | Answered on Jun 01, 2012
okay you need to take your DVD to a repair tech.what happen since you have not used over some years the solder on the circuit board might have gotten corroded causing minimal current to pass through the DVD.in other words your DVD siezed up.or probably you might have to in vest in a new DVD recorder.. if you dont use your electronics product for a period of time that will happen.electronic items needs to be used offten. good luck.
Lite On LVW-5101... | Answered on Sep 25, 2011
The laser in 5101 could be defective or maybe just dirty.Try cleaning with a commercial cleaning disc,put a drop of rubbing alcohol on cleaning brushes.When this happens sometimes it will still be a usable disc but not always.Try putting in another dvd player or recorder or your PC if it plays dvds,the readers in PC are of a better quality and will often read discs that those cheap dvd readers can't.
R+ or R- discs need to finalized after recording RW+and RW- discs do not.It is always a good policy to finalze the second your recording is finished otherwise it may not play in other players or recorders.
When you make a recording in a dvd recorder an it doensn't recognize the disc it just recorded it quite often has a defective laser.This particular model has been plagued with early laser failure.
Lite On LVW-5101... | Answered on Aug 10, 2009
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Lite On... | Answered on Aug 22, 2017
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Lite On... | Answered on Jan 17, 2017
try nte.com semiconducter
Lite On... | Answered on Jan 02, 2014
FIrst switch Off the power supply.There is a hole just beneath the DVD tray. take a thin wire or unfold a office paper clip.Push the wire gently and the DVD will come out. There can be a mechanical failure, due to which it happened. switch On power supply, take our DVD try two -three times, if it works normally then i think ou problem is solved
Lite On... | Answered on Dec 25, 2013
Lite On LVW-5101 DVD Recorder Logo
Popular Tags
14 questions posted
Top Lite On Televison & Video Experts
Jaime Hernandez
Ekse
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Lite On Televison & Video
Most Popular Question
need owner 39 s manual
  • Televison & Video
