20 Most Recent
Pentax ZX-30 35mm SLR Camera Questions & Answers
Repair
If you are using standard or "Heavy Duty" batteries, this is not unexpected. Try Alkaline or even better, rechargeable NiMH batteries, they have a much longer life. Some of the earlier digital cameras were real power hogs.Hope that helps,Bax
Lens zx 30
is the mirror stuck up? Lots of these ZX Pentax models have failure of the mirror motors when the plastic gear on the shaft of the motor cracks and then the motor just runs continously
All my photos are coming out blurry
There are only a few things that can cause this problem.
1. the mirror is not seating all the way down.
2. the pressure plate on the back door is loose.
3. the diopter on the finder is not adjusted to your eye.
4. long exposures ( vibration ).
Check your lenses with a different camera body.
Check your negatives with a magnifier. it could be printer problems.
Lens problem...
You are experiencing lack of communication between the shorter lens and the camera body. Since the longer lens works correctly the problem is in the other lens and not the camera body.
BTW-the numbers 62mm & 55mm are probably the filter sizes for each lens and not the focal lengths. Unscrew the filters and you will probably find a name ring on the lens signifying the type of lens it is(e.g. 28-80 or 70-200 or something like that.)
Look at the rear mount of the problem lens. There are some small metal(5-6) contacts there. Make sure the contacts are clean. If not, clean them with a soft rag or Q-tip. If they seem to be OK then there may be a problem inside the lens with the flexible printed circuit(FPC). The FPC may have been damaged somehow. If this is the problem take the lens to a competent repair shop and have them evaluate it. Depending on exactly which lens it is, it may be cheaper to replace the lens rather than repair it--but have it looked at anyway. Hope this helps.
Flash on all time in auto
Please, which camera model? Are we talking about the external flash or one built in? If it is built in the camera may think there is not enough light thus setting the flash to fire. That is what auto does, it takes all the decisions away from the camera operator.
11/28/2016 2:46:07 AM •
Pentax...
Answered
on Nov 28, 2016
