Mitsubishi PD-4225 42 in. Plasma Television
Problems with Mitsubishi PD-4225 42 in. Plasma Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Mitsubishi PD-4225 42 in. Plasma...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Mitsubishi PD-4225 42 in. Plasma Television RSS Feed
View More Results for Mitsubishi PD-4225 42 in. Plasma Television
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi PD-4225 42 in. Plasma Television RSS Feed
Answer
The picture is fine all over the screen except for two areas. There are two strips of lines about 2... (More)
Answer
Answer
Hi three says ago my tv was working fine during the morning but at night when I turned it on i could... (More)
Answer
I turned on my unit and the picture is very dull and snowy or fuzzy. All inputs are the same. red... (More)
Answer
TV worked fine, just moved. No visible damage to TV but it doesn't get power. It won't turn on.
Answer
Hello, i have vertical muli color lines on my plasma display on all inputs. inputs work. can you... (More)
Find a Manual
Mitsubishi PD-4225 42 in. Plasma Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Polaroid flm-373b lcd tv black screen control box no power fix
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked.... written by stiv0
Enter expert mode on LG TV
For the 44" LG DLP model RU44SZ63D...press and hold the menu button the remote control until a four digit password is requested on the screen.... written by mlapres
Tv troubles
the newer tv are just computors in disguyes.they often won't come after a power surge and have to be reset,you must unpluge from the wall and wait 10... written by bsddog87
Falt Panel Screen Cleaning
If you are trying to clean a LCD or Plasma screen, use only recommended screen cleaners. Be very careful not to rub too hard or contrast coating may... written by edcor
TV has snowy picture or displays unusable signal, no signal or no sync.
What to do if you have an all snowy picture, blue screen or the TV displays unusable signal, no signal or no sync. When using a Satellite receiver or... written by johnnydiode
how to test flyback without taking it out of the board
a) basically it has to be acted upon by a supply voltage of at least 95V to work. b) of course, assuming the horizontal deflection oscillator works,... written by palaboy
Universal Remote Controls.
The worst yet creation to the electronics entertainment industry is the universal remote control. If you have problems with your original remote... written by fieldy14
Problems with warranty companies?
If you are having grief getting a poduct looked at, repaired or replaced whilst it it still under the manufacturers 12 month gaurantee, as long as you... written by fieldy14
WikiManual
(Post a New Chapter)
How to Mount a Plasma TV on a Wall
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's... by wikihow
How to Connect a TV to a DVD Player Without A/V Jacks
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for PD-4225 42 in. Plasma Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the Mitsubishi PD-4225 42 in. Plasma Television
Owners Recommend
out of 4
Reliability
Ease of use
Value for Money
Find a Warranty
Specifications for Mitsubishi PD-4225 42 in. Plasma Television
Key Features
Screen Size
42 inch
Flat Panel Type
Plasma
Display Resolution
852 x 480 pixels
Display Capabilities
Aspect Ratio
16:9
Display Format
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Image Quality
Contrast Ratio
1,000:1
Comb Filter
Digital 3-Line
Brightness
1000 cd/m²
Technical Features
Picture in Picture
With PIP
Dimensions
Depth
10.88 in.
Height
27.63 in.
Width
49.63 in.
Weight
81.7 lb.
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Top Flat Panel... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
