20 Most Recent
Sharp LC32SB28UT 32 in. HDTV LCD Questions & Answers
I have picture but no sound HELP
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Reset audio
Hi Chance,
FYI.
https://www.google.lk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&cad=rja&ved=0CGoQFjAH&url=http%3A%2F%2Fwww.helpowl.com%2Fp%2FSharp%2FLC-32SB28UT%2FResearch%2F76033%3Fsearch%3Dsharp%252032%2520lc32sb28ut&ei=ZpLPUtC4LOn6iQe51YEo&usg=AFQjCNFrAqFZXE71Qr5FVcnpEbhCTD4igA&sig2=zJU5OMykglEmwPFDvi89ng&bvm=bv.59026428,d.aGc
Tv trouble i need some troubleshooting help
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves
checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
Does Sharp LC-42SB48UT TV support
PAL-M is 525 line 29.97 frames per sec, PAL-N is 625 line 50 frames per sec. Most countries (e.g. UK) use PAL B/G/D/K/I which is 625 line 25 frames per sec. PAl-M is used in Brazil, PAL-N is used in Uraguay and Paraguay. Most modern TVs will handle both PAL and NTSC as long as the RGB input is used (via scart or HDMI).
