Mitsubishi VS-60609 60 in. Rear Projection Television
Problems with Mitsubishi VS-60609 60 in. Rear Projection...?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Mitsubishi VS-60609 60 in. Rear...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Mitsubishi VS-60609 60 in. Rear Projection Television RSS Feed
View More Results for Mitsubishi VS-60609 60 in. Rear Projection Television
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi VS-60609 60 in. Rear Projection Television RSS Feed
Answer
middle of screen coming in on the sides and turning green
Answer
my tv mitsubishi vs 60609 60 in. has a yellow tint and makes fuzzy noise. how can i fix. help
Answer
My mitsubishi vs60609 has lost some of its coloring. It seems to have lost shades of red. Then every... (More)
Answer
My vs-60609 turns on for several seconds then it clicks off. Sometimes there is a picture, sometimes... (More)
Answer
Where can I find a platform for this set? It is too low for our theater seats
Answer
I have a mitsubishi 60 inch big screen model vs-60609 that has no picture. When you power it on the... (More)
Answer
I have a Mitsubishi vs-60609 60" projectiong tv. The Blue color shifted to the right giving... (More)
Find a Manual
Mitsubishi VS-60609 60 in. Rear Projection Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Mitsubishi VS-60609 60 in. Rear Projection Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the Mitsubishi VS-60609 60 in. Rear Projection Television
Owners Recommend
out of 4
Reliability
Ease of use
Value for Money
Rate and Review the Mitsubishi VS-60609 60 in. Rear Projection Television
Write a review:
Rate this product:
Would you recommend the VS-60609 60 in. Rear Projection Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Mitsubishi VS-60609 60 in. Rear Projection Television
Key Features
Screen Size
60 inch
Remote Control
Remote Control
Multibrand
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Variable / Fixed
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Picture in Picture
With PIP
Sleep Timer
With Sleep Timer
Screen Text
Closed Caption on Mute
With Closed Caption On Mute
Dimensions
Depth
29.13 in.
Height
60.88 in.
Width
50.5 in.
Weight
251 lb.
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
