No picture - just sound. The picture faded away and never came back while watching it. Only the...
(More)
No picture - just sound. The picture faded away and never came back while watching it. Only the sound is working.
It stays on for a different length of time each time it's turned on. Sometimes will work for many...
(More)
It stays on for a different length of time each time it's turned on. Sometimes will work for many hours per night and 4 or 5 nights, sometimes will stay on for only a few minutes. When it shuts down, you see the 3 color horizontal lines (r,g,b) colapse toward the center of the screen and then goes black and the power goes off. You can immeditely turn it back on, but it will shut down again quickly. if it sits for a while it will stay on for a longer time, usually. I tried to re-solder all the connections on the 3 - CRT circuit boards, since this was a common issue that supposedly caused this problem, but that didn't help.
Mitsubishi model VS-50805 rear projection tv. The color will change from green to red back to...
(More)
Mitsubishi model VS-50805 rear projection tv. The color will change from green to red back to normal. I've had it looked at twice and have been told the one of the bulbs is bad ? Does that sound right ?
maatmartin7 needs help! I have mitsubishi vs 45607, made feb 2001. I repaired the powersupply board...
(More)
maatmartin7 needs help! I have mitsubishi vs 45607, made feb 2001. I repaired the powersupply board and repaired the small signal board [aka convergence board] The tv worked great for two weeks. and has a new problem I cannot solve. I have repeatedly pull the boards out to solve. This is what it does. The picture is to wide [ Horizontal width]for the screen. The width is normal when contrast and brightness are set at minimum. Of course the picture is very dim. The width will travel beyond the screen when raising contrast and brightness. Will a bad flyback cause this. If not where is the problem?
When you try to turn it on, the green light comes on and shuts right back off??? It will not power...
(More)
When you try to turn it on, the green light comes on and shuts right back off??? It will not power up.
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
