20 Most Recent
Briggs & Stratton Starter Scott's Equip S2046 Briggs Stratton 20hp Questions & Answers
Briggs & Stratton 20hp Intek engine over-revving continuously.
Do you have governor adjusted properly? Possibly "PidStu" question, but you'd be surprised how many I've seen. Can you move the governor linkage arm with your fingers or does it seem to be locked in position? If it is locked, it is adjusted improperly.
6/1/2022 10:53:14 AM •
Briggs &...
Answered
on Jun 01, 2022
How do i replace the bladeees belt?
Remove the deck, Find the pattern of the belt direction on each pulley. While deck is removed check for sharpening blades and greasing spindles.
5/13/2016 7:26:09 PM •
Briggs &...
Answered
on May 13, 2016
Can you replace the fuel primer rubber part? If so, part # and instructions?
Go to a small engine shop and they will have what you need If possible take the old one on and even if its pulled apart they can give you a new one. Give them the make and horse power.
There is a little steel some are plastic ring you have to take out to get the bulb out. I got mine with a small screwdriver. In putting the new one in make sure the area is clean and shove the new bulb in and put the ring over top and use a socket that will just slip in and tap it in as far as it will go.
3/17/2015 12:50:52 AM •
Briggs &...
Answered
on Mar 17, 2015
Engine idoling way to high
An engine will idle too high because of : improper govenor setting, improper carb setting, intake leak, or missing carb throttle plate.
10/25/2012 5:52:45 AM •
Briggs &...
Answered
on Oct 25, 2012
The plastic starter gear keeps
The lawn mower you have is manufactured by the John Deere Company. They handle all inquiries and complaints on these lawn mowers. You can contact them at 800-537-8233
Hilary @ Scotts
5/16/2011 8:14:14 PM •
Briggs &...
Answered
on May 16, 2011
I have a scotts/john deere
I would try and fill the case with 50 weight oil It might be low. The hose should come to the right side of the pully door on the middle of the tractor between your legs.
Terry
1/10/2011 7:57:48 AM •
Briggs &...
Answered
on Jan 10, 2011
The mower deck belt on my scotts s2046 comes off
you should have some type of belt tensioner,most common type is a pulley with a spring to hold pressure on belt.Spring may be missing or stretched {2}belt could be stretched {3}pulleys may be out of alignment
10/6/2010 5:47:42 AM •
Briggs &...
Answered
on Oct 06, 2010
Briggs & stratton 17.5 hp has fuel, spark and good air filter no start.
Likely either the engine is flooded or low compression.
A simple go no go compression test is remove spark plug and press a thumb or finger firmly over the plug hole and crank engine. It should forcibly push your finger and make a loud PFFfft sound. No or little sound equals insufficient compression.
If the push rod was not bent, there was no reason to replace. If it was bent then I question how you set proper valve lash with new pushrod as the typical cause for a bent rod is a displaced valve guide.
If compression is OK then likely it's simply flooding and you have a carb float/inlet needle issue. Crank engine, remove plug and if it's saturated with fuel then it's flooded and a flooded engine will not fire, even with starter fluid.
Comment for further assistance.
11/6/2023 1:03:20 AM •
Briggs &...
Answered
on Nov 06, 2023
