20 Most Recent
Bushnell Laser Rifleshotgun Scope Boresighter Questions & Answers
I have a Bushnell Bore Sight with multiple
You can buy a laser bore sight that looks like a bullet that shoots a laser out. You just load it like a bullet and then sightyour scope to match it at the proper yardage. If you can remove the action(like with a bolt action) then you could just sight down the barrel(with the rifle in a gun vise) and then adjust your scope to point at the same thing you see through the barrel.
Eyepiece assembly bushnell telescope
You never told us what model number or telescope TYPE you own. Is this a refractor or a reflector. ???
If a REFRACTOR usually you have a diagonal, the diagonal goes into the focuser and then the eyepiece goes into the diagonal.
On a REFLECTOR the eyepiece goes directly into the focuser.
Bushnell Tour v3 laser rangefinder will not display yardage
Please shutdown your device for 5 minutes, booot up and then check for yardage again. If this does not work, then you might look into the device manual (in troubleshooting) to check for an alternative approach to fixing this. Thank you.
