20 Most Recent Mitsubishi WS-65905 65" Rear Projection Television Questions & Answers
Fixya is unable to suggest parts sources.
Mitsubishi... | Answered on Nov 27, 2017
http://www.manualslib.com/manual/769299/Mitsubishi-Ws-65903.html
Mitsubishi... | Answered on Jun 05, 2016
Your blue picture tube is failing. Invest in a new TV. "If" you can find a new set of tubes(you have to replace all 3 red blue and green) they are around $800-1000. Not cost effective. Run the TV into the ground if you want to wait but do not invest any repair money in my opinion.
Mitsubishi... | Answered on Jun 03, 2015
Even if a convergence problem exists you should still have a picture, a bad one but a picture----call the menu up with the Mitsubishi remote and select convergence and then advanced---a grid of lines will appear in green---got dramatic red and blue showing and you have a convergence issue.
Do that first----presuming no hookup is ok (try a dvd player) the set does have the OPTION menu(can tell you how to get there) that is based on a 4 digit number code--may have that for this model or not).
It will not correct any convergence problems but will do a hard reset of the set back to factory original.
Let me know what you find---it sounds like 2 problems exist.
Mitsubishi... | Answered on Nov 15, 2012
Sorry ,when this activity starts the inevitable is about to happen but who knows when 1week 6months??. I know this is not what you want to hear and sorry it is what it is . The only thing you can check is all your connections and make sure they are tight if they are sorry, but who knows you may be one of the lucky ones and something is loose. Also if your on an antenna this could cause it as well. Good luck and Please rate my solution that is how we get our points and achievements Thank You in advance.
Mitsubishi... | Answered on Apr 10, 2012
dust this tv havr fuse and where ,what tv it look like 3d but is not
Mitsubishi... | Answered on Nov 17, 2010
Yes it does, you should not unscrew the red screws only the gold ones in the corners of the tube.
What is the symptom of the problem that you are having.
You will need to ensure that all of the liquid is off of the circuit boards as soon as possible as it will wick under the IC's on the board and quickly ruin them.
Please let me know if you need more help or assistance.
asnowman
Mitsubishi... | Answered on Oct 08, 2010
Please do self check model listed has: when power light goes off on front of set press and hold both the menu and input buttons for at least 5 seconds and release both.
Power light should blink two digit error code like: 2 blinks, 2 blinks, a pause and repeat 4 more times.
Let me know what error code and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Mitsubishi... | Answered on Aug 21, 2010
First: this model has three picture tubes--with lens--if they are dusty the picture will be duller and darker than it should be--if this was the case it would be the same HD or not.
Do not pay someone to do this--with set off and unplugged you will see the three lens--clean them with a lens cloth.
Second possible cause---CONVERGENCE.
This set has in the customer menu convergence adjustments done with the remote---they are separate in the HD from the non HD. They are done with the Mitsubishi remote and easy to do.
If convergence when you call up the menu for it the grid of yellow lines will have either red or blue out of position slightly.
A lot of these sets were never very well adjusted in the HD mode for this---check out the convergence in the NON HD FIRST!
Then go to a HD channel and call it up again---instructions on how to move, adjust etc will appear and you will know instantly if convergence is different on HD---easy to adjust.
If this works and you want to get the Convegence really good let me know--there is a way by model number to do the same adjustments but it saves them into the memory of the set.
Doing the adjustments in customer mode, if power is removed they may return to what they were before.
If all this information has helped you rate this solution as very helpful as I do this here for free.
SD TECH
Mitsubishi... | Answered on Aug 16, 2010
yes its ethilyne glycol (antifreeze)
Mitsubishi... | Answered on Feb 04, 2010
I have the same problem. I had someone come out and take a look at it they told me it was a DM module or signal board. Unfortunately Mitsubishi does not make the part anymore!! I'm very upset. I'm not saying this is your problem, but look at it as a possibility...
Mitsubishi... | Answered on Jul 19, 2008
This behavior could be an indicator of power supply problems or abnormal current drain from elsewhere in the set.
Modern supplies are, by design, able to shut down if voltage or currents aren't within the design limits of the circuits they are servicing.
Without some hands-on it is not possible to isolate the problem unless one of the forums deals with a series fault.
If the set had a reset button, it would be located on the outside of it where the user could reset it.
The reset buttons one finds on some sets is nothing other than a very cheap kind of thermal circuit breaker that trips when current is above its limit.
These are kind of prone to failure themselves.
Mitsubishi... | Answered on Jul 13, 2008
How did you get 720p? I have having trouble viewing anything above 480p. When using my directv HD DVR, the screen goes black when it tries to show anything above 480p. Is it the tv or the DVR?
Mitsubishi... | Answered on Jan 10, 2008
When I took mine apart, I had to unscrew all the screws on the pegboard, then there are some screws along the midsection on both sides. Other than that, there weren't any cables or anything to be leary of. It was really pretty easy. Hope that helps.
Mitsubishi... | Answered on Jan 07, 2008
What is going on with green? I may can help
Mitsubishi... | Answered on Dec 27, 2007
i cant hook up my xbox 360 hdtv settings
Mitsubishi... | Answered on Dec 24, 2007
Very common problem with this set. The convergence IC's both need to be replaced. if your not a tech with solid state soldering experience I would seek out a trained service person to assist you in this repair.
Mitsubishi... | Answered on Sep 06, 2006
Mitsubishi WS-65905 65" Rear Projection Television Logo
Popular Tags
22 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
red tube off
  • Televison & Video
