Mitsubishi WT-46805 46 in. Rear Projection Television
Problems with Mitsubishi WT-46805 46 in. Rear Projection Television?
Troubleshooting and Support
Solved Problems for Mitsubishi WT-46805 46 in. Rear Projection Television RSS Feed Post a New Problem
Mitsubishi WT-46805 46 in. Rear Projection...
I'm getting audio but no video-- Previously whenever text came onto the screen my lines were off-- Now I can't get any...
1 Solution
Projection bulb
There are actually three tubes in this unit: blue, green, and red. They would not all have gone out at once, and that...
1 Solution
PCBs/Fluid
OK, so, where are the PCBs and if I see fluid, what do I do about it? Are there replacements and how much $ do you think...
1 Solution
Mitsubishi WT 46805 ~ Picture gone........
We have the 46" Mitsubishi WT-46805 - and all of the sudden today the picture is in and out... When we turn it on -...
1 Solution
1998 mitsubishi big screen tv model...
blue picture tube light up at the bottom but the blue ray that shines on the screen will not light up is there a bulb in...
1 Solution
help
blue screen only when you turn tv on I tried to turn off and on unplug and plug in thought someone might have hit wrong...
1 Solution
Mitsubishi WT-4605 - picture going dark,...
The picture on our set fades out and finally goes black.  Comes back again good as new and goes thru the process...
1 Solution
Unsolved Support Problems
Unsolved Problems for Mitsubishi WT-46805 46 in. Rear Projection Television RSS Feed Post a New Problem
Power but no picture.
My friend gave me his Mitsubishi model WT-46805 HD 1080 series T.V. because it did not work for him anymore. I thought...
Post a Solution
problem with picture
double picture,bowed on side wt 46805. tried the color convergence did'nt work. any suggestions. Thanks ahead of time
Post a Solution
Red lines around the contours - Mitsubishi...
Hello, This unit was given to me recently - problem: matching red lines appear around white (and light color) images -...
Post a Solution
HD does not work w/ verizon fios
when i go to menu, then to input, the memorize channels does not include HD-1080DTV. The input is DTV. All I get is a...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Screen Size46 inch
Audio Features
Sound LevelerWith Audio Leveler
Technical Features
Picture in PictureWith PIP
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Sponsored Links
Loading problems.
Top Experts
Ask Me
BIG IRISH Wiz
70 solutions
Ask Me
Terryfic Guru
31 solutions
Ask Me
skippy101 Wiz
7 solutions
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
