Mitsubishi WS55857 tv turns on but screen is blue it shows no picture. the satellite is on and it...
(More)
Mitsubishi WS55857 tv turns on but screen is blue it shows no picture. the satellite is on and it shows the banner of what tv show should be playing at the top when you cange the channel but we cannot see a picture. Changing the input button does not help.
hello i am getting no picture blank screen and does not show any display mode like channel ect but i...
(More)
hello i am getting no picture blank screen and does not show any display mode like channel ect but i have sound
Every once in a while my Mitsubishi WS-65869 loses it's color a little and it starts to look like an...
(More)
Every once in a while my Mitsubishi WS-65869 loses it's color a little and it starts to look like an old fashioned picture. Is there an IC chip or two to replace?
TV switches on but no screen, green light blinks the usual 3 times on startup and stays on. Heaters...
(More)
TV switches on but no screen, green light blinks the usual 3 times on startup and stays on. Heaters all working on the CRTs. It acts like there is no signal to power up the high voltage (just my unknowing anything about electronics guess). No buttons other than power work on remote or console. Tried unplugging console. Is there a power relay and a way to check it?
When I turned the set on saturday the picture just looked like a cartoon. I don't know of a better...
(More)
When I turned the set on saturday the picture just looked like a cartoon. I don't know of a better description.
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
