Mitsubishi WS48511 48 in. Rear Projection Television
Problems with Mitsubishi WS48511 48 in. Rear Projection...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Mitsubishi WS48511 48 in. Rear...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Mitsubishi WS48511 48 in. Rear Projection Television RSS Feed
View More Results for Mitsubishi WS48511 48 in. Rear Projection Television
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi WS48511 48 in. Rear Projection Television RSS Feed
Answer
The picture comes and goes on my Mitsubishi 48511 The error code is one and then two . I understand... (More)
Answer
Trouble shooting has yielded an error code of 22 "Short Protect". TV will not turn on. How... (More)
Answer
mitsubishi ws48511 has plaid rolling screen in front of picture on every input. when using the menu... (More)
Answer
Mitsubishi WS-48511 Rear Projection. Solid green screen but audio is fine. Please advise.
Answer
the power got turned off; now the TV won't come on; all I get is a flashing green POWER light. Help.
Answer
The mirror inside my MItusibshi WS48511 broke, and I'm looking to get a replacement from a local... (More)
Find a Manual
Mitsubishi WS48511 48 in. Rear Projection Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Mitsubishi WS48511 48 in. Rear Projection Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the Mitsubishi WS48511 48 in. Rear Projection Television
Owners Recommend
out of 2
Reliability
Ease of use
Value for Money
Rate and Review the Mitsubishi WS48511 48 in. Rear Projection Television
Write a review:
Rate this product:
Would you recommend the WS48511 48 in. Rear Projection Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Mitsubishi WS48511 48 in. Rear Projection Television
Key Features
Screen Size
48 inch
Display Capabilities
Aspect Ratio
16:9 · 4:3 Enhanced
Remote Control
Remote Control
Multibrand
Image Quality
Velocity Scan Modulation
With VSM
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Fixed
Audio Type
Virtual Surround
Technical Features
Picture in Picture
With PIP
Sleep Timer
With Sleep Timer
Screen Text
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Dimensions
Depth
24 in.
Height
48.75 in.
Width
44.5 in.
Weight
180 lb.
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
