20 Most Recent Mitsubishi VS-70707 70" Rear Projection Television Questions & Answers
Do a hard reset or factory reset and it should work again
Mitsubishi... | Answered on Dec 15, 2017
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Mitsubishi... | Answered on May 11, 2017
TRY UNPLUGGING FOR 10 SECONDS, IF NO WORK , CONTACT TECH SUPPORT, AND EXPLAIN ERROR CODE
Mitsubishi... | Answered on Nov 10, 2013
YOU NEED TO CALL THE MITSUBISHI TECH SUPPORT, THEY SHOULD BE ABLE TO TELL YOU FOR FREE THE POSSIBLE TROUBLE...JUST EXPLAIN THE ERROR CODE..GOOD LUCK
dOES SET COME ON WITH POWER LIGHT ON AND A FEW SECONDS LATER SHUTS OFF?
WHEN it turns off press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both.
watch for power light to blink a two digit error code like 1 blink, 2 blinks and then pause and repeat the code for about 5 times .
Let me know what code you find .
Mitsubishi... | Answered on Dec 21, 2012
Televisions covered: typical Projection Televisions.
Projection TV's usually have a bezel surrounding the screen that is held on by a (firm) friction-fit to a rubber gasket.
Once the bezel is (carefully) removed, the screen itself is released.
How to remove the bezel: carefully pull it away from the cabinet of the TV (toward the front), by hand - its somewhat/slightly flexible. If a tool is used, one risks damaging the cabinet finish, or the bezel itself.
If I need to extract a screen, I'll usually release the upper 1/2 of the bezel from around the screen (removing the top and half of each side), then lift the screen panel itself up and out of the TV without removing the entire bezel - this way, I save the (unnecessary) work of removing the entire bezel, and also avoid the possibility of the screen panel falling out of the cabinet onto the floor in front of the set (as the last part of the bezel comes off the cabinet).
Its often tough to get this bezel off the first time, so when I take one off, I'll install a light coating of grease on the rubber gasket, since once it comes off the first time, it will inevitably need to come off again a few more times before the TV is fixed. And if the bezel is flexed too violently, it will break.
Cheap automotive bearing grease works fine.
Mitsubishi... | Answered on Dec 23, 2011
I know who answered the other question, do you want to attempt the hard reset for this model?
Mitsubishi... | Answered on Nov 23, 2011
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
sj
Mitsubishi... | Answered on Oct 28, 2011
Find an active TV Repair shop. You may find a used screen in their salvage area. If they don't have one, they will know of another TV shop that may. Thanks for asking and show all hands of support!
Mitsubishi... | Answered on Sep 06, 2011
RESOLDER ALL DRIED JOINTS
Mitsubishi... | Answered on Aug 01, 2011
Try websites like Tvrepairworld.com,Tvrepairkits.com to buy refurbish any DLP tvs pcb boards.They're the hugest dealers for DLP tvs parts around.
Mitsubishi... | Answered on Jun 27, 2011
I don't know of a parts outlet but searching will find this part. I am betting that you blew out the video card itself. This usually happens with a lightning strike or a power surge and a power surge strip you buy from a home center is not what it advertises and will not work. It will be obvious if you pull the back off of the TV and look at the input cards, one of them should be fried. If you find the fried one you can pull it, take off the part number and start looking for a replacement. These cards can be fixed but it will take someone that knows what they are doing and a ton of patients.
Mitsubishi... | Answered on Jun 16, 2011
The number one item for that model is to check the Circuit boards for signs of CRT coolant dripping on the boards which appears as a clear sticky residule. Very common proble with that chassis. You should be able to get parts from www.tvrepairworld.com they can get the hard to find parts.
Mitsubishi... | Answered on Jun 11, 2011
set should have 2 cable connecters; IF IT DOES NOT CONNECT VIA CABLE BOX/SAT BOX ETC TO ONE OF THE SETS OF AUDIO/VIDEO JACKS ON BACK OF SET AND USE IT THAT WAY----the AV jacks bypass the cable fitting.
Tuner could be removed and coax fitting replaced but just go around the problem.
If you do not understand, comment here and I will explain.
SD TECH
Mitsubishi... | Answered on Jun 02, 2011
Mitsubishi VS-70707 70" Rear Projection Television Logo
71 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
mitsubishi model vs 70803 not
  • Televison & Video
