I have a Mitsubishi HD 1080 Projection TV that keeps turning off on its own and does not want to...
(More)
I have a Mitsubishi HD 1080 Projection TV that keeps turning off on its own and does not want to come back on. Sometimes it will work all day and sometimes it shuts off immediately when I turn it on.
i have a mitsubishi ws-55613 projection tv. the overall color looks green and is much darker that it...
(More)
i have a mitsubishi ws-55613 projection tv. the overall color looks green and is much darker that it use to be. was working great. any help would be appreciated.
I am trying to get my Mitsubishi 1080 rear projection tv on imput componet to 1080i but it is saying...
(More)
I am trying to get my Mitsubishi 1080 rear projection tv on imput componet to 1080i but it is saying 480
I have a mitsubishi ws-55613 that has started to flicker after 5 to 10 minutes (looks like v-hold is...
(More)
I have a mitsubishi ws-55613 that has started to flicker after 5 to 10 minutes (looks like v-hold is messed up) and the sound goes out. If you shut off the tv and turn it back on, it works, but for a shorter period of time. Any help would be appreciated. Could I get a manual? Know anyone that would fix it?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
