20 Most Recent Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Questions & Answers
http://www.shopjimmy.com/mitsubishi-930b929001-power-supply-unit.htm replace this part
Mitsubishi... | Answered on Aug 25, 2015
Is there any noise coming from the cable box? My TV had similar problems, and when I had Comcast change the faulty box, the problem stoped
Mitsubishi... | Answered on Jul 02, 2014
you can reset the tv to factory default settings , but before that I need more info ab manufacture date and purchase date you can find the first one on the back cover, if the tv has more than 5000 hrs of use problably the lamp, filter or fans can cause this problem, hope it helps you . let me know
Mitsubishi... | Answered on May 10, 2014
Can't see any reason why not, as long as it has the same specifications!
Mitsubishi... | Answered on Apr 23, 2014
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
Which light is flashing red? Reply to this same post and I will assist you with the problem.
Mitsubishi... | Answered on Mar 13, 2014
YOU TV LAMP IS GONE. REPLACE IT.
I can help you if you send me a line at savenergy@rogers.com or call me with a message at 8473806394 with your phone number.
Mitsubishi... | Answered on Nov 02, 2013
you have to make sure you get the plug on the lamp fitting sits right so it will go home to the other end. make sure its not broken or moved as it will not locate on to the other end when fitting.
Mitsubishi... | Answered on Oct 05, 2013
If you have a voltage meter there are some things you can check.
Unplug the unit and remove the back cover of the set. Then Plug the unit back in.
You will need to tape down the lamp safety switch in order to do these tests.
Here are all the failures that would give you a lamp error and what to check.
Cause 1. Unit powers on and works properly for a while then shuts off with a red lamp led(lamp error). Suspect bad lamp and replace.
Cause 2. Unit does not power up correctly and you have red lamp led(lamp error). Check the lamp enable line at connector J14 on the back of the light engine. If pin 6 does not switch to 5 volts after turn on, but your 12 and 5 volt supplies are good, then suspect a defective light engine.
Cuse 3. At power on the lamp turns on and off 3 times and then the unit shuts down with a red lamp led(lamp error). You have a defective light engine.
Cause 4. Unit does not turn on correctly and you have a red lamp led(lamp error). Check for 12 volts at connector J9 pin 4 on the light engine. If voltage is missing check for an open fuse F9A09 on the power supply board. If it is open, then you need to replace the fuse and you still have a defective light engine.
Cause 5. Lamp enable line at connector J14 pin 6 on the light engine does go to 5 volts at turn on, but does not drop back to 0 volts after 5 seconds, but your 12 and 5 volts supplies are good then you have a defective light engine.
Cuase 6. Check for 5 volts at connector J9 pins 1 and 2 on the light engine. If low or missing check Capacitors C9A37 and C9A38. Values are 3300MF/10V. Replace capacitors if defective.
This is all I have and I wish you luck.
Mitsubishi... | Answered on Mar 20, 2013
your air filter cover is loose or not on.
Mitsubishi... | Answered on Jan 26, 2013
Look to see if same issue with the audio and video inputs on rear, usually a problem with lines will not come and go but, it may be possible.
Also it is possible if you snap a good photo to post it here to be seen.
Mitsubishi... | Answered on Dec 10, 2012
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
140 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
install
  • Televison & Video
