Mitsubishi WS-55313 55 in. Rear Projection HDTV-Ready Television
Problems with Mitsubishi WS-55313 55 in. Rear Projection...?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Mitsubishi WS-55313 55 in. Rear...
Troubleshooting and Support
Solved Problems for Mitsubishi WS-55313 55 in. Rear Projection HDTV-Ready Television RSS Feed
View More Results for Mitsubishi WS-55313 55 in. Rear Projection HDTV-Ready Television
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi WS-55313 55 in. Rear Projection HDTV-Ready Television RSS Feed
Answer
I have a WS-55313. The screen will go totally blue and a message appears that says- tv will shut off... (More)
Answer
moved mitsubishi ws 55313 now it has 11 multiple pictures streaming left across the screen and a... (More)
Answer
mitsubishi ws-55313 wont turn on. led comes on for a couple seconds then shuts off gives me error... (More)
Answer
i did the code thing on my Mitsubishi ws-55313 it came up the 2,2 code can you help me fix it ??
Answer
I have a ws55313 that wont turn on any more, I pulled the board tray out and found one fuse that was... (More)
Find a Manual
Mitsubishi WS-55313 55 in. Rear Projection HDTV-Ready Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Mitsubishi WS-55313 55 in. Rear Projection...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Mitsubishi Convergence IC Part Number List
As there has been some serious errors made in identifying the IC's for Mitsubishi Convergence, I have posted the complete list for your use.... written by toddg
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Mitsubishi WS-55313 55 in. Rear Projection HDTV-Ready...
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Mitsubishi WS-55313 55 in. Rear Projection HDTV-Ready Television
Key Features
Screen Size
55 inch
Display Format
1080i (HDTV) · 480p (EDTV) · 480i (SDTV)
Digital TV Standard
HDTV-Ready
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
NTSC
Remote Control
Remote Control
Multibrand
Illuminated Remote
Illuminated
Image Quality
Velocity Scan Modulation
With VSM
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Variable / Fixed
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Connectors
Headphone Jack
Without Headphone Jack
Rear Input Connectors
Component x 2 · S-Video x 2 · DVI x 1 · Composite x 2 · RF x 2 · 1 x RS-232C · Audio (RCA) x 6 · RGBHV (BNC) x 1
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1
Rear Output Connectors
Composite x 1 · Audio (RCA) x 1 · RF x 1
Screen Text
OSD Languages
English · Spanish
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 10 Watt
Dimensions
Depth
25.63 in.
Height
50.5 in.
Width
50.5 in.
Weight
245 lb.
Warranty
Overall Warranty
1 Year
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
