20 Most Recent Mitsubishi WL-82913 82" Rear Projection HDTV Questions & Answers
You can try ordering this from Express Repair Center.
2196 NW 82nd ave.
Miami FL 33122
Toll Free 1-877-260-9965
tel: 305-500-6334
fax: 305-500-6339
You can also order this part from their page, but I would recommend you to call them before placing any orders, the link to the page is:
http://www.ercservice.com/lamps/mitsubishi-lamps/915P016010.html
Mitsubishi... | Answered on Feb 28, 2013
bulbtogo $169,00 plus s+h
The model does not show, what is correct model:??? WD?
Mitsubishi... | Answered on Dec 22, 2012
We have the same problem. A 14,000 dollar TV that you cant even get a lamp for. I 'm thinking of a class action lawsuit. This is ********!!!!!!!!!!!!!!!!!!!! Please respond if your interested
Mitsubishi... | Answered on Jul 26, 2011
bulbtogo $169.00 plus S+H
Mitsubishi... | Answered on May 09, 2011
Mats Electronics Sales Lamps for $89.00- $139.00 1-800-628-1118
Lamp PN# 915PO16010
Look on EBay under Electronics TV/Parts type in Lamp number.
Mitsubishi... | Answered on Feb 17, 2011
bulbtogo.com 169.00 +s+h
Mitsubishi... | Answered on Dec 04, 2010
bulbto go.com $169.00 plus s+h,however,get housing for bulb as well-this will probably save you many problems.
It is a capacitor on a circuit board. You access it from the back of the tv, however I do not remember much more about the repair except that there were two identical capacitors, and the repairman changed them both out in about 10 minutes. Still charged $200.00 plus dollars for the repair, but apparently he knew extractly what the problem was with doing any other testing so it must be a common problem with the set.
Mitsubishi... | Answered on Dec 27, 2009
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Mitsubishi... | Answered on Jun 29, 2009
try and unplug it from the wall. This should restart the computer. If that doesn't work, you should probably look at buying a new television set.
Mitsubishi... | Answered on Dec 28, 2008
does the lamp indicator light as red? let me know what the status light does...is it blinking or solid give me some info and I should be able to help you also mitsubshi had some problems with jamicon capacitors with a thousand uf and above ratings that are no good 95 percent of all dlp problems can be traced to those bad capacitors
Mitsubishi... | Answered on Apr 12, 2008
Well for the first guy, it would seem something came loose while moving it. Trace your power circuit to find the ecaxt problem, as well as inspect your fuse.. I'm sure its something simple and since it wont come on it has to be that it aint getting power..
For the second guy,, the reson why he baked off and said call the manufacture is caue you proberally need a MAIN BOARD... I would suggest you take it to a secon technician first and herr what he has to say before calling the company for they to tell you,,... you have to buy a mainboard and it will cost you some money ...
Mitsubishi... | Answered on Jan 18, 2008
Mitshubishi part #934C066001.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Mitsubishi... | Answered on Jul 13, 2007
Mitsubishi WL-82913 82" Rear Projection HDTV Logo
Popular Tags
25 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WL Mitsubishi
  • WL Mitsubishi
Most Popular Question
in need replacement lamp mitsubishi
  • Televison & Video
