20 Most Recent Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Questions & Answers
press menu and input both in together on the front of the TV and hold them both in together for 8 seconds then let me know if the LED blinks a two digit code.
Mitsubishi... | Answered on Dec 27, 2016
Thanks for your help can you send photos so I can see what to look for
Mitsubishi... | Answered on Oct 10, 2016
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Mitsubishi... | Answered on Dec 23, 2012
there is a converter box , where you can connect everything and convert in to hdmi output , you can buy this boxes on the internet or at the redioshack
Mitsubishi... | Answered on Oct 12, 2012
Your tv is either 1080p or not 1080 compliant. Try 720p or you may be forced to keep it at 480
Mitsubishi... | Answered on Sep 17, 2012
if colors look skewed and come and go----next time enter the convergence menu on the set and call up advanced---a grid of lines should appear---if skewed when set bad (lines should be yellow) you have a common issue---convergence----the model indicated uses two stk-394-250 chips and both would have to be replaced.
Mitsubishi... | Answered on Aug 27, 2012
No much unless you have a service manual and a meter to test things--2,3 means a deflection problem which usually means a short in the sweep circuit.
This kind of problem rarely gets fixed in the home but the set has a removable light box--all the guts come out in one piece except for the speakers and front keyboard--box can be operated out of the set as the remote receiver is up top near the lens.
Mitsubishi... | Answered on May 16, 2012
Most of these sets have two tuners--one for main and one for PIP.
If main picture works fine but PIP is bad or Green? either the PIP tuner or the PIP board is bad---these were known to have the PIP have problems but it was more rare than their sets made before it.
SD TECH
Mitsubishi... | Answered on Apr 26, 2012
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
106 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
ws 55315 tv turn
  • Televison & Video
